Kodak K-14 Process
 Share
Hello 435,
Kodachrome film is supplied in three ASA's-25,64,200. Characteristics of
film-Outstanding grain and sharpness,vivid color,natural skin tones. Try
some 25 ASA sometime! You'll be impressed! I think kodachrome may be
my favorite color film. I do not like Fuji greens. Film is processed in K-14
Lab Processor. Dryer Tank is at temp. of 105F. A chiller system in the pro-
cessor achieves temperature specifications inside the developer tanks. Water
is mixed between 85F and 100F for processor use,this is done via intellifaucet
connections. Process:
1. First Developer And Wash
2. Cyan Developer And Wash
3. Yellow Developer And Wash
4. Magenta Developer And Wash
5. Conditioner And Bleach
6. Fix,Wash,Final Rinse
If you get a chance photograph a beautiful movie star with Kodachrome 25,
use flash. Make sure you ask her for permission to photograph her! Always
ask for permission and you will develop a reputation.
Greg
Link to comment
Hello 435,
E-6 process is simple for still film, any good photography book will
explain how to do it,chemical process etc..You can actually develop
film at home and mount slides yourself. One question though are you
talking about movie reversal film or still film? Movie reversal film is
different and must be sent to labs that perform the service. Kodak has
listing on this subject on their web site. Kodak has formulation of chem-
icals on their website for K-14,E-6 a little hard to find but its there. E-6
can be done at home easily. K-14 is different animal,rigid control needed.
Greg
Edited by pd170user
Link to comment
Hello Again 435,
I forgot to tell you that Kodak has darkroom manuals for chemicals
and processing of film. Contact them on website and inquire how to
obtain. If you are interested in the chemicals you'll need a manual.
Maybe Mr. Pytlak will be on our forum(Kodak) and will reply. He's on
forum a lot. Best regards. If you have difficulty finding info get back
to me and I'll help you find.
Greg
Link to comment
Many years ago Kodak maintained a monopoly on processing Kodachrome. Then the courts ruled that they had to release the formulas to the commercial labs. So they did. As far as I know, a few tried to run the process for a while and then gave up as it was so complex.
It's a different type of process from Ektachrome, in that the dyes are added from the developer, rather than being in the emulsion in the first place. That allows them to use different dyes, which is why it's such a superb stock: but it's clearly too hard for the average home darkroom. Quality doesn't come easily!
Link to comment
Hello 435,
Here is process for E-6 which you can do at home unlike K-14. Process
as follows:
1. Pre-wet film in tank,no agitation.
2. First Developer,agitate first 15 sec. then for 5 sec.
every 30 sec..
3. Water wash and change water frequently
4. Color developer,agitate first 15 sec. then 5 sec. every
30 sec..
5. Water wash for 1min. 30 sec. and change water frequently
6. Bleach/fix,agitate first 15 sec. then 5 sec. every 30 sec.
7. Water wash and exchange water frequently
8. Stabilizer, agitate first 15 sec. only
9. Dry film, time will vary due to where you hang film to dry.
For this process at home you can use tank&reel,manual or motorized agitation,
table top processor(expensive). Tank & reel will do you well and agitation is not
hard at all,you get practiced with it. One problem you may see is that you will
have in-consistant color and tone through out roll of film with improper agitation.
As a young photographer I processed many rolls of ektachrome in my darkroom.
You can buy E-6 kit at photo supply stores. I did not give times and temp. for each
step due your kit will tell you that. Greg
Link to comment
If you have no darkroom experience you may want to learn to work
with b&w film first in the darkroom. This will get you used to agitation
method,washing,drying film. Transfering film from its own roll unto the
tank reel for development, is a little hard first time around in the dark.
If you have a friend who does darkroom work or know a photographer
who will help you,that would be a good start. You do not need to buy a
whole lot of expensive equipment if you are on a budget. Of course once
the film is sealed in the tank you can turn the light on. Temperature may
be maintained by keeping chemicals in their bottles in a plastic tub along
with development tank. Aquarium heaters or photographic heater(sold by
photo stores may be used). It really is a thrill the first time to hang a roll
of ektachrome up to dry and look at your images. I do not know anymore
what is available to mount slides but you can get paper or plastic slide
frames and devices are available to cut and mount them. Of course you
can practice telling a story with slides/slide film. All of Kodak's darkroom
manuals are excellent. If you are going to do any T-Max let me know and
I will save you a lot of headaches! With most of the E-6 kits you can use
solutions at various temps. from about 75F to 110F. Best regards!
Greg
Link to comment
If anyone is wondering about why Kodachrome cannot be processed at
home,will discuss as follows: Its usually processed in a Kodak K-14 Lab
Processor. Kodachrome has 3 light sensitive layers,each containing sep-
erate b&w emulsions with different color sensitivities. The top layer is sen-
sitive to blue light,the middle layer to green and the bottom layer to red.
There is also a yellow layer positioned below the blue to keep blue light
from effecting bottom layers. After the film is processed the yellow filter
layer disappears. Each b&w layer(emulsion) records light in proportion to
the original colors of the subject. The blue sensitive layer,for example,re-
ceives the most exposure from blue parts of the subject. In the first dev-
eloping stage ,the film turns in to the equivalent of three different b&w neg-
atives,with silver density deposited on each layer according to the amount
of exposure each area of that layer has received. A blue jacket for example
will record with greatest density on the film's blue layer. The second develop-
ment reverses the image to create a positive and introduces dye in each layer
according to that layer's sensitivity(original exposure). The dyes form the Im-
age color. The film is then bleached and fixed. Thus Kodak K-14 Lab Process-
or is required. I send my kodachrome to Philadelphia and it takes me 3 to 4
days to get my slides back. Greg
Link to comment
The K-Lab guide to processing KODAK KODACHROME films in the K-14 process:
http://www.kodak.com/global/en/service/Zmanuals/z50.shtml
http://www.kodak.com/global/plugins/acroba...uals/z50_03.pdf
(NOT easy to do at home)
And only a handful of labs left in the world:
http://www.geocities.com/thombell/k14.html
Here is the much simpler E-6 process for KODAK EKTACHROME films:
http://www.kodak.com/global/en/professiona...0.14.3.22&lc=en
http://www.kodak.com/global/en/service/Zmanuals/z119.shtml
Link to comment
Thanks all, My question was about formula of developer
not all the developing process.
I've enough darkroom experience, even more than enough.
Im cooking developers and fixers in our lab (in VGIK)
last year we spoke about this process and people told nobody knows how to cooke developer for it. I told may be its secret but may be not ?
thats why im asking here
which and how much chemicals inside of this developer ?
second question is new :)
where can i see expamles of this process (I mean photos)
which latitude had or still have this positives? (gamma, gradient, Dmin Dmax and most interesting color curves)
thanks again...
Link to comment
Many motion picture labs mix their own solutions, and the formulae are published by Kodak:
http://www.kodak.com/US/en/motion/support/....4.5.16.8&lc=en
Premixed "Kit" chemicals are also available, and used by labs that don't have a staff chemist or analytical capability:
http://www.kodak.com/US/plugins/acrobat/en...4.11.6.10&lc=en
The on-line Kodak processing manuals and film technical data often show the effect of processing variations:
http://www.kodak.com/US/en/motion/products...d=0.1.4.4&lc=en
Link to comment
Are we talkin about K-14 ?
because I coulnt find there. its all about motion picture processing...
I think Kodak didnt published formula of K-14 developer.
I believe the chemicals were available as pre-packaged "kits":
http://www.kodak.com/global/plugins/acroba...uals/z50_04.pdf
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
