Premium Member Damien Bhatti Posted October 8, 2008 Author Premium Member Share Posted October 8, 2008 One kidney and your first-born son. P This can be arranged ;) ..so my only option is digi beta. I cant afford hdcam and theres no way that I am going to be dabbling in 35mm (at the moment) Link to comment Share on other sites More sharing options...
Premium Member Keith Mottram Posted October 11, 2008 Premium Member Share Posted October 11, 2008 Budget Mac based solution is as follows: Use Macpro with internally raided hard drives plus kona 3 card. take dpx files and wrap them with ajaDPX tool. use compressor to make hd pro res files. edit in fcp. reconform from wrapped dpx files. send to color. grade. send to fcp. export different formats for viewing/ put onto film. Link to comment Share on other sites More sharing options...
Premium Member Bruce Taylor Posted October 13, 2008 Premium Member Share Posted October 13, 2008 My project is 16mm. Someone mentioned optically blowing up to 35mm from a 2 k scan. If I were to be using 35mm negatives then your suggestion of a photochemical finish is the one I would take. Once you start looking at any kind of 35mm finish, you really need to consider originating in 35mm. It is often the least expensive way to go. Stay a little off the beaten path and there are great deals out there. I collected a few tips here: http://www.indi35.com/tips_and_links Bruce Taylor www.Indi35.com Link to comment Share on other sites More sharing options...
