Jeremy Russell Posted December 11, 2004 Share Posted December 11, 2004 On a film for a class this summer I was reading about a 2.4 off of a meter measuring footcandles, however, my a-minima internal meter was reading a 1.9 or a 1.4. Exposed at 2.4, it was perfect. Apparently, the meter reads the light coming off of the film. For those more experienced than I, should you trust these internal light meters? Jeremy Link to comment Share on other sites More sharing options...
Premium Member Nathan Milford Posted December 11, 2004 Premium Member Share Posted December 11, 2004 The A-Minima's light meter is usually correct. Perhaps yours needs service or something was dialed into the menu incorrectly. Link to comment Share on other sites More sharing options...
Mike Welle Posted December 11, 2004 Share Posted December 11, 2004 Were you taking an incident or reflected reading with your handheld meter? The A-Minima meter is an incident meter, so if you were taking an incident reading with the handheld something would be off. If you were taking a reflected reading with the separate meter that would explain the discrepancy. By the way you can emulate an incident reading with a reflected meter by taking a reading off of the back of your hand and using it as a portable "gray card." On a film for a class this summer I was reading about a 2.4 off of a meter measuring footcandles, however, my a-minima internal meter was reading a 1.9 or a 1.4. Exposed at 2.4, it was perfect. Apparently, the meter reads the light coming off of the film. For those more experienced than I, should you trust these internal light meters? Jeremy <{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
Dirk DeJonghe Posted December 12, 2004 Share Posted December 12, 2004 The A-Minima exposure meter is really to be considered an 'external meter' even if it is build-in. It does not read through the lens but is a standard incident light meter. So if you keep the camera on the tripod if will just read the light falling on your right shoulder. If used hand-held the camera needs to be held with the plastic dome on the right hand side of the camera at the subjects position facing the camera position. Link to comment Share on other sites More sharing options...
