Does anyone know the easiest places to purchase chinese lanterns? Just needed to light a scene with them. Please let me know of the stores that would definitely carry them. Thanks.
This is one of the cheapest places to buy them
But shipping it out to you will take around a week
http://paperlanternstore.com/evriropala.html
http://paperlanternstore.com/24evriropala.html
If you're in a hurry Pier 1 or Target are your safest bets
Also you're better off building your own sockets
Just get 'em at Home Depot and buy the wiring it's simpler than baking a cake :)
Good Luck
Do any of you dunk your lanterns in some kind of fire retardant, or (like me) just keep a close eye on them while shooting? Any good "flame-out" stories?
Although there are warning that it can burn I've never seen one burn.
I've had them on for hours (probably as much as 6 hours once)
Running with 500w light bulbs in them and they've never burned.
Though usually I don't use anything stronger than 250w
& no lantern smaller than a 16'' diameter.
What I've seen get damage however are the sockets
The ones that can't hold more than 150w get f%$ked up real easy
When you put anything over 150w in them.
Maybe someone should do a lab test to see:
When and in what conditions a Paper Lantern will burn up.
I wonder who'd be willing to fund that?
Edited by Rik Andino
You know I've only ever had one problem with that and that is when a hot bulb touched the lantern. I always use a ceramic socket affixed to a length of threaded lamp rod that goes into the grip head. That prevents the bulb from touching the lantern.
