beegblock Posted April 21, 2005 Share Posted April 21, 2005 Hi, I filmed something on my MiniDV camera in NTSC format and was wondering if there was any way to turn it into a PAL final product on DVD. I'm assuming if there's a way, it would be done via the program I'm using to edit? It's Premiere 6.0. Thanks! Link to comment Share on other sites More sharing options...
Chance Shirley Posted April 22, 2005 Share Posted April 22, 2005 (edited) I'm starting to look at the same issue myself. I haven't figured out all the answers, but there are two big things you have to take care of -- frame rate and resolution. Specifically, you have to change the frame rate from 29.97 fps to 25 fps, and you have to "blow up" your image to 720 x 576 pixels (from 720 x 480). I don't know if you can do this in Premiere, but I think After Effects might be able to handle it. At least according to this page: http://www.toolfarm.com/tutorials/ntscPAL.html Good luck... Edited April 22, 2005 by chance Link to comment Share on other sites More sharing options...
Guest Posted April 22, 2005 Share Posted April 22, 2005 Highly doubtful you can do this with Premiere. You can export your NTSC video as a PAL quick time movie, use the settings 720X576, 25 FPS, DV PAL. Now you have a PAL file but you'll see lot's of distortion on any medium to fast movement in the shot, or when there's a camera pan you'll see distortion. If the shot is a lock off of a building it will work, but movement will do the shot in. There are software solutions for this, but not one built into Premiere that I know of. Richard Link to comment Share on other sites More sharing options...
