Premium Member Max Jacoby Posted March 27, 2004 Premium Member Posted March 27, 2004 I am a bit perplexed, someone told me that British Terrestial Television is in 14/9. Is that true for every program? So basically either of my televion's setting (4/3 or 16/9) will distort the picture...
Premium Member David Mullen ASC Posted March 28, 2004 Premium Member Posted March 28, 2004 How are they handling that format in the U.K. for broadcast? I figured 14x9 was only for letterboxed 4x3 TV viewing as a way of transitioning people to the wider 16x9 sets eventually -- but that the post work was being done in 16x9. But are widescreen TV sets sold in Britain 16x9 or 14x9? Do they transmit separate 16x9 and 4x3 letterboxed (to 14x9) signals?
Mitch Gross Posted March 28, 2004 Posted March 28, 2004 I thought the 14/9 had to do with TV safe cutoff protection. Phil?
Premium Member Phil Rhodes Posted March 28, 2004 Premium Member Posted March 28, 2004 Hi, > figured 14x9 was only for letterboxed 4x3 TV viewing as a way of transitioning > people to the wider 16x9 sets eventually Precisely. This means that essentially ALL TV framing in the UK is currently a compromise, and it sucks. To be more precise, analogue terrestrial is often 14:9. Only a few news networks, principally ITN, still shoot and broadcast 4:3. All other stuff is shot 16:9 (hence the uselessness of my 4:3 video camera) and broadcast in 16:9 full height anamorphic on terrestrial and sattelite digital, and converted to 14:9 for terrestrial analogue. The idea is that if you are using digital TV you have a set-top decoder which then has the responsibility of converting the image in realtime to suit your output device. However, if people have widescreen TVs, they generally just watch everything stretched out to fill the display; likewise, if they're watching a 16:9 DVD on a 4:3 TV, likely everything'll be tall and thin. In practice all this stuff is wrong much more often than is right and it will continue to be so until such time as we outlaw the use of 4:3 TVs! Phil
Premium Member Tony Brown Posted May 31, 2004 Premium Member Posted May 31, 2004 Everything I shoot for UK is shot 16:9 (unless I can persuade them to shoot 2.35:1 for TV which I manage ocasionally) The only time I've found 14:9 to be a consideration is for BBC broadcast such as the D Day trailers I shot recently. When doing do I still shoot 16:9, but treat 14:9 as a safe area if the shot requires a safe area as such at all. So far I've never had to do this, so I compose and shoot 16:9. Going back to 4:3 (when shooting for US or France for example, also a lot of stuff for Sky) I find really dull for most projects. Most sets have a 14:9 setting that I've ever looked at, the exception being my current Panasonic Plasma.
