Dave Stroup Posted March 13, 2021 Share Posted March 13, 2021 (edited) I recently picked up a Beaulieu 4008 ZM II with the ANGENIEUX 1.9/8-64mm lens. When zooming out to a wide angle a squealing sound / squeaky like noise occurs. This noise only occurs during the second half of the zoom range (from approximately 30mm to 8mm). If I let the camera sit by the window in the sunshine for a bit (warm it up) this noise goes away and the zoom is quiet. I assume this must be a lubrication issue(?). Does someone know how I might try to lubricate the Reglomatic Zoom Control on this camera? I’m tempted to hit it with some DeoxIT, but I’m not sure if that’s a good idea and I don’t want to make things worse. Any advice would be appreciated. Thanks! Edited March 13, 2021 by Dave Stroup Quote Link to comment Share on other sites More sharing options...
Bjorn Andersson Posted March 17, 2021 Share Posted March 17, 2021 This "noise" is depending on that booth motor and lens has dried out. It will not help with some spray or similar. To cure it, lens and the reglomatic unit has to be dismantled old dried oil/grease has to be removed and re-oiled. As lens has to be stripped it will need a collimation to work properly again. Quote Link to comment Share on other sites More sharing options...
Dave Stroup Posted March 18, 2021 Author Share Posted March 18, 2021 Thank you for your thoughtful reply Bjorn! Quote Link to comment Share on other sites More sharing options...
Andries Molenaar Posted March 22, 2021 Share Posted March 22, 2021 On 3/18/2021 at 8:54 AM, Dave Stroup said: Thank you for your thoughtful reply Bjorn! Now sell your car when you want the work done 🙂 Possibly best to ship to Bernie at super16inc. He is a certified lens repair specialist. Angénieux and Schneider or what more. Quote Link to comment Share on other sites More sharing options...
