Alexa Mini $46,990
Hours:558
4:3 & ArriRaw
PL LDS mount
Viewfinder
VF Cable
Center Handle
BPA4
BAP1 plate
MSB1 side bracket
MAP2 adapter plate w/rod support
VF mounting bracket
WC A Box
Power Supply
WC D Box gold mount
Compact baseplate CBP1
LWA adapter
2x256gb 2x128gb Cfast Cards
Jason Case
Alexa Mini $43,500
Hours:2834
4:3 & ArriRaw
PL mount
18” Iris rods X2
BP-8 X1
ARRI antenna X2
Shoulder pad CSP-1
ARRI TOP HANDLE CCH-2 WITH HEB-2 EXTENSION
MAP-2 X2
ARRI VF
VIEWFINDER CABLE X2
Wooden camera DBOX
ETHERNET CABLE
MSB-1 X2
BPA-4 X1
ARRI Top handle CTH-1
ARRI VF BRACKET ASSEMBLY
VIDIPONS 12” sliding base plate
MAP-1 X2
RMB-3 X2
15mm insert sleeves X2
ANGELBIRD 256 GB CFast card (brand new)
ETHERNET CABLE
CUSTOM ALUMINUM Lemsford case
Alexa Mini $41,500
Hours:1600
4:3 license
Look Library
PL mount
Viewfinder
2x VF cables
2x Sandisk 256gb Cfast cards
Tilta Sliding plate
Tilta Shoulder pad
2x12” 15mm rods
2x4” rods 15m LWS
Tilta Vmount Cage:
Top handle w/power pass thru
VF Holder
2x15mm top rod adapters
19mm rod adapter
15mm LWS to 19mm rod adapter for LCD
Long top plate w/power pass thru
Short Top & bottom plate
EXT to EXT cable
15mm LWS baseplate
2x15mm x 80mm rods
Top plate to battery brige plate w/pass thru
Right & left side arm
Battery plate 15mm LWS rod adapter
Vmount
Brand New Jason case
bvw@vidgear.com
