Jonathan O'Neill Posted June 26, 2021 Share Posted June 26, 2021 Hi, do any brands of LED fixtures allow for the base kelvin in HSI mode to be adjustable? So at 0% saturated it could be 3200k and not 5600k which is all I can find currently. also, which brands have accurate lee gel settings? Once again with the option for that gel to be added to an adjustable base kelvin. cheers Quote Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted June 26, 2021 Premium Member Share Posted June 26, 2021 Some of them let you select HMI or tungsten as a basis for the gel simulation, at least. I'm trying to think which. I may have some stuff in storage that will do it; I could drag it out if you need to try something. It's worth bearing in mind that the gel simulations are often a bit approximate. Many of them, for instance, will offer you Lee #181, Congo Blue, which is fundamentally unavailable from almost all LEDs because it's deeper than the blue of the base emitter. Quote Link to comment Share on other sites More sharing options...
Matthew Parnell Posted June 29, 2021 Share Posted June 29, 2021 Kino Celebs and the Litemat Spectrums do natively. Skypanels and Vortex8’s allow you to do this via DMX by using the cross fade channel. Set the saturation to 100% and use the cross fade channel as your saturation. Quote Link to comment Share on other sites More sharing options...
