I was wondering what the main differences between Pizar RX lenses compared to Kern Sitar RX lenses? I often see the Pizar lenses selling for much lower on ebay. Are Kern lenses sharper and superior? Any info would be much appreciated.
Thanks!
Kern made both Switars and Pizars. The Pizars were a cheaper option, usually 1/2 to 2/3 the cost of a similar focal length Switar, but not as cheap as the Yvar range, which were mostly simple triplets and cheaper again.
I don’t know exactly what corners were cut to make Pizars cheaper. The f/1.5 25mm Pizar has pretty much the same 6 element optical formula as the f/1.4 25mm Switar, so maybe they used lower grade glass, or reduced tolerances. Originally it was labelled a Switar (the f/1.5 version, which was cheaper than the f/1.4) but sometime after reflex cameras were introduced it was re-labelled Pizar and only available as an RX option.
The 50mm Pizar is a different design to the Switar, 5 elements instead of 6, and a bit slower at f/1.8.
The  image quality is still pretty good as far as I can tell, but I’ve never seen a side by side comparison. Unless you’re fastidious about getting the best image possible with a Bolex (in which case maybe sell a kidney and go for the later pre-set versions), I think I’d be happy with a Pizar.
thanks for the information, Dom!
