Jon O'Brien Posted September 25, 2021 Share Posted September 25, 2021 If you could choose between a slightly worn SR3 that has seen much use, or an immaculate German-modified SR which has hardly ever been used, and assuming both have been recently checked and both run fine, and are up-to-date with battery supply etc, which would you prefer? Is the SR3 significantly quieter? I'm guessing, if the SR3 is a bit old, then not necessarily. Link to comment Share on other sites More sharing options...
Jon O'Brien Posted September 25, 2021 Author Share Posted September 25, 2021 And let us further assume that both were in Super 16 -- that the SR had been converted and had a SR3 S16 gate in it. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted September 25, 2021 Premium Member Share Posted September 25, 2021 I think SR3s are much better cameras all round. If the SR has been converted, make sure it was a proper conversion with modified mirror/shutter, recentred mount and optics, modified mags and an actual S16 gate, some early modifications were a bit dodgy. The interiors of SR mags have often deteriorated with age, so that the rubberised paint has become sticky and can interfere with the film, so check that. I think even a well-used SR3 would be quieter. A lot of use is ok as long as it had a bit of maintenance and wasn’t subjected to salt water or lots of fine sand etc, or stored in a damp, musty basement. 1 Link to comment Share on other sites More sharing options...
