Carlo Molinari Posted May 28, 2022 Share Posted May 28, 2022 Hi everybody, I’m having few issues with the Arri IVS HD on the Arricam ST. When we switch on the camera we always see this glitch. Any idea about to fix it ? p.s. we have already send it back to the rental house but we still have it. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted May 28, 2022 Premium Member Share Posted May 28, 2022 Not really the sort of problem that can be diagnosed over the internet, the rental house needs to sort it out. But obvious things to check are the cables and monitor, so if you can swap those over it will isolate the problem. If it still happens then the issue is the IVS itself and an experienced electrical tech needs to look at it. Link to comment Share on other sites More sharing options...
Roni Beraha Posted May 28, 2022 Share Posted May 28, 2022 Do you use cold packs on the IVS? Because when the IVS get too hot it starts acting weird. You have to keep it cold. Link to comment Share on other sites More sharing options...
Carlo Molinari Posted May 28, 2022 Author Share Posted May 28, 2022 hi roni, you are not the first to give me this tip. Yesterday during the second day of the set since the IVS returned from the rental house, we found that that problem occurs in the first hours of work of the IVS, once it goes to temperature it no longer gives this problem. Consider that we 're are shooting at night so it is quite cool (21°/15°) It seems that noise in the upper right box appears when the exposure is too low. We have disabled all the automatic controls, so we are working in Manual with the gain. Link to comment Share on other sites More sharing options...
