I've got a Canon 1014 Electronic and XL-S and would like to know how they rate the various super 8 stocks around. From what I have read some stocks that are out now there is no official S8 notch , like 200t/250D/500T
I am a bit confused on which rating it would select. On both camera's I always shoot with the red filter removed either by screwing in a screw or a switch. Does this change the rating and make it more or less off?
The stocks that I use are:
V3 50D
Ektachrome 100D
V3 200t
V3 250D wound by Pro8mm
V3 500T
Then I know how I may compensate for the wrong rating either by setting a manual aperture or using the comp dail on the XL-S
Regards
  • 3 weeks later...
Hi!
Simply use this ruler: http://www.peaceman.de/blog/index.php/super-8-notch-ruler-new-and-improved
(BTW: The Vision3 50D is notched as 40D and the 200T as 160T. The difference is very, very small and negative filmstocks don’t mind a little over-exposure. And the Ektachrome 100D is notched as 100D. So, there’s nothing to worry about when using the camera’s autoexposure with these three filmstocks - as long as you are using a fully working camera that „knows“ 40D, 160T and 100D. But that’s what you need the ruler for. Not sure about the other filmstocks.)
Hope this helps
Jörg
  • Like 1
