MITCHELL JUNIOUS Posted August 5, 2023 Posted August 5, 2023 I have an Aaton XTR Prod with an Aaton VideoSync Assist. I usually just use the viewfinder but recently thought I was use the video tap. When I plug an external monitor (black magic video assist 5") in via sdi it does not show an image. Is there something that I am missing? I thought it would be pretty simple just plug and play, but it doesn't seem to be so unless I'm making a simple mistake. Either way I would be extremely grateful for any help.
Premium Member David Sekanina Posted August 5, 2023 Premium Member Posted August 5, 2023 (edited) if you have the old standard def video tap, the video signal is composite video, not SDI. You need a composite to SDI converter. Blackmagic sells compact ones. Edited August 5, 2023 by David Sekanina
