Tom Hepburn Posted March 17, 2010 Share Posted March 17, 2010 And what's about the Schneider Cinegon 10 mm c-mount ? Will it cover Super-16 too ? I have that lens and it does cover my ACL II super 16 with no vingetting. I've never used it with a bolex though. Tom Link to comment Share on other sites More sharing options...
Jean-Louis Seguin Posted March 17, 2010 Share Posted March 17, 2010 Wide open was pretty lousy Precisely what I said. Cheers, Jean-Louis Link to comment Share on other sites More sharing options...
Sir Alvin Ekarma Posted March 17, 2010 Share Posted March 17, 2010 Precisely what I said. Cheers, Jean-Louis Not to nitpick, but I'd say being able to shoot at f2 (or f2.2 or f2.8) and up still makes the angenieux a solid lens and I'd be happy to use any lens that works in that range; losing 1/2 to 3/4 to 1 stop on the wide end of a faster-than-normal vintage lens isn't a deal breaker. Heck, I've tested a 25mm switar RX wide open and that didn't end up super duper either-- the image just fell apart in its own way (went all muddy and grainy if I recall). Again, just sayin ;) Link to comment Share on other sites More sharing options...
Chris Millar Posted March 17, 2010 Share Posted March 17, 2010 ... better than the 16-100 RX poe zoom at 16mm and at the same f-stops. The 16-100 POE isn't exactly Kerns best lens optically ... But yes, stopping down will help a lot in both cases - I have been hesitant to buy a 5.5mm aspheron for my 10mm preset since I found an element from an old sigma zoom fitted perfectly in the lens shade and gave me almost equivalent FOV and looked fine when stopped down. :lol: Speaking of that lens shade - I wonder sometimes if it is simply the lens shade causing the vignetting on some 10mm presets, maybe an extended length shade from a 26mm has ended up on a 10mm, or they've been stacked and its simply causing a physical vignette rather than just the optical formula falling apart at the extremes (?). There is a large 'I read it on the net so it must be true' factor when it comes to Bolex huh - aware all the while that we are adding to it right now :rolleyes: Link to comment Share on other sites More sharing options...
Jean-Louis Seguin Posted March 17, 2010 Share Posted March 17, 2010 The 16-100 POE isn't exactly Kerns best lens optically ... But yes, stopping down will help a lot in both cases - I have been hesitant to buy a 5.5mm aspheron for my 10mm preset since I found an element from an old sigma zoom fitted perfectly in the lens shade and gave me almost equivalent FOV and looked fine when stopped down. :lol: Speaking of that lens shade - I wonder sometimes if it is simply the lens shade causing the vignetting on some 10mm presets, maybe an extended length shade from a 26mm has ended up on a 10mm, or they've been stacked and its simply causing a physical vignette rather than just the optical formula falling apart at the extremes (?). There is a large 'I read it on the net so it must be true' factor when it comes to Bolex huh - aware all the while that we are adding to it right now :rolleyes: When the 10mm preset is used for super16, all filter retaining rings must be removed or it will be visible in the frame as vignetting. Unfortunately, I have found that the 5.5 Aspheron on the 10mm preset gives a vignetted image. However, the Century adapter works well. Cheers, Jean-Louis Link to comment Share on other sites More sharing options...
kevin jackman Posted March 18, 2010 Share Posted March 18, 2010 When the 10mm preset is used for super16, all filter retaining rings must be removed or it will be visible in the frame as vignetting. Unfortunately, I have found that the 5.5 Aspheron on the 10mm preset gives a vignetted image. However, the Century adapter works well. Cheers, Jean-Louis I hope this isn't for all of them. sigh Link to comment Share on other sites More sharing options...
Phillip Mosness Posted March 1, 2013 Share Posted March 1, 2013 Well it looks like the filter rings may be why I had severe vignetting with my first test footage. I'll try again with those off and I bet I'll see a big change. Oddly, the previous owner has lots of nice filters for the lens, but how he used them is now baffling given what I see happening with them on the lens. He claimed not having any problems like this. On a separate note, I've heard that gel filters are more consistent than glass anyway. Not sure if that's true, but it may be my only choice. Link to comment Share on other sites More sharing options...
Chris Millar Posted March 2, 2013 Share Posted March 2, 2013 Suspect there was vignetting but it was zoomed in on in transfer and the recipient was none the wiser. Link to comment Share on other sites More sharing options...
Garrit Speiss Posted July 18, 2023 Share Posted July 18, 2023 On 3/10/2009 at 8:41 PM, Kori Perez said: Who is going to pay for the stock, processing, and transfer? ? I have water footage with an ND 0.6 at F5.6... I'll post a clip or grab if interested I will - Garrit Speiss FB/IG Link to comment Share on other sites More sharing options...
