Sign in to follow this
tristan
wide angle
I would like to know how to achieve fish eye look on XL1 ?
Should I go for the century attachment OR mini35 adapter with Zeiss wide angle lens?
Thanks!
Share this post
Link to post
Well if you like spending outrageous amounts of money then go for the mini35. But you can get the same "fish eye" look with the Century adaptor for I'm guessing 1/10th the price.
Share this post
Link to post
well of course I am going to rent it for my coming project but just thinking which one to go for?
Can I use mini35 with Fish eye lens or even 10mm? does it sound logic?
Share this post
Link to post
It'll work. The thing you have to watch out for are those "block" adaptors where you clamp on a 35mm lens straight to the camera. There's a magnification effect on most of them (even the Canon eos adaptor). So a fisheye lens might not look fisheye enough. But the mini35 projects an image on the CCDs. So you should get the same or close to the same image a 35mm camera would. That's why they're so popular and so expensive. But I'd suggest unless you going for a theatrical screening the Century adaptor would be sufficient. It was used on "Full Frontal."
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    FJS International
    Just Cinema Gear
    The Original Slider
    G-Force Grips
    Cinematography Books and Gear
