Adam Froehlich
ARRI MMB-2 Loose Rod Bracket
There's considerable play in the mounting points for the 15mm rod bracket on my Arri MMB-2 matte box.  It seems to be on a part that can't simply be tightened, but is embedded.  It's just a tiny variance at the actual rod, but that little bit gets translated into a considerable wobble at the top of the mattebox once it's mounted on rods.  Does anyone know how to tighten this up?  Are these little mounting points threaded into the mattebox itself, or embedded?
The mattebox itself is fairly new, bought new Winter 2018, and has really only seen light work in the studio (only 1 or 2 operators/assistants)
Photos attached, Video for reference:
In the video, the mounting bracket is rock solid on the mounting points, it's the points themselves that have movement.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    G-Force Grips
    The Original Slider
    Just Cinema Gear
    FJS International
    Cinematography Books and Gear
