Jonathan Chong Posted November 3, 2023 Posted November 3, 2023 Hey there, I have a Schneider-Kreuznach Beaulieu-Optivaron f1.4/6-70 mm lens and once I remove the Reglomatic motors the aperture ring is really loose. I'm wondering if anyone knows how to give the aperture ring more resistance so that I can use it manually and keep the aperture in place without it being accidentally moved out of position. Is there a dampening ring that can be installed on it or any other tricks? Thanks
Mark Dunn Posted November 3, 2023 Posted November 3, 2023 https://www.amazon.com.au/BOSTIK-BLU-TACK-S050Q-Bostik/dp/B001FGLX72
Joerg Polzfusz Posted November 3, 2023 Posted November 3, 2023 Why did you remove the motor anyway? If you need the plain C-mount-version, I would recommend buying it instead of damaging the Beaulieu-specific extensions that weren’t supposed to be removed.
Mark Dunn Posted November 4, 2023 Posted November 4, 2023 On 11/3/2023 at 9:58 AM, Jonathan Chong said: Ha ha. Very funny Quite serious. I've used it to fix focus for timelapse. Gaffer tape is probably a more filmic answer, if you have some, because it doesn't shed adhesive. 1
Jonathan Chong Posted November 5, 2023 Author Posted November 5, 2023 On 11/4/2023 at 7:55 AM, Joerg Polzfusz said: Why did you remove the motor anyway? If you need the plain C-mount-version, I would recommend buying it instead of damaging the Beaulieu-specific extensions that weren’t supposed to be removed. Because I can't afford to buy another version.
