Danner Gardner Posted March 22 Share Posted March 22 (edited) Sent my SR3 advanced on a job. During prep when testing the start stop trigger on the WCU-4, the camera wouldn't run and just made a long beep sound and display showed 0 fps. They were running a lot of accessories off the camera body (teradek, WCU-4, small-hd onboard, HD-tap, cinetape). I'm thinking that the camera was just overloaded on the power and the start/stop was the straw that broke the camel's back. I went to check the fuse though and didn't see an accessory fuse, only the main 10amp. I noticed in the SR3 manual the cameras with newer electronics have a self-resetting fuse. If this is the case, shouldn't the fuse have reset itself and work now, or is there potentially a worse problem at hand? Any help would be appreciated! Here's a video link with the problem that's happening Edited March 22 by Danner Gardner grammar error Link to comment Share on other sites More sharing options...
Robin Phillips Posted March 22 Share Posted March 22 so I've never run into this on an SR3, but self resetting fuses take time to reset (can be minutes or more). And if you still have all those accessories attached after the rest, you may still have the same problem. I specifically run some accessories off my battery or battery plate's additional power plugs whenever possible just to not tax the aging electronics. if its urgent this might be a call Andree sort of thing if you're in LA and see, should it remain problematic, if he can do an emergency check on it. But I think the max draw should be in the SR3 manual, and if all those devices add up to more than the body can handle you know what went wrong. Link to comment Share on other sites More sharing options...
Helge Abrahamson Posted March 23 Share Posted March 23 Since display is on and out of sync sound is working, I don't think it's a power problem. My guess would be a broken drive belt - does inching knob feel different than usual? 1 Link to comment Share on other sites More sharing options...
Danner Gardner Posted March 23 Author Share Posted March 23 Helge, you may be on to something. I just noticed the “asy” error on the lcd. Inching knob does feel tighter than usual. If I keep inching it it feels more normal and the camera runs fine, then eventually stops again with the same error and the inching knob feels tight. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted March 24 Premium Member Share Posted March 24 That sounds like way too many accessories to be running from the camera (RS outputs can only handle about 2.5A), but it sounds like you have other problems if the camera is now still not running properly. Best take it to an Arri tech to diagnose and fix. 1 Link to comment Share on other sites More sharing options...
