Sinan Gökhan Posted April 17 Share Posted April 17 Hello everybody, when camera set with Cine EI, i chance iso numbers nothing change on EVF what should i do? Link to comment Share on other sites More sharing options...
Gabriel Devereux Posted April 18 Share Posted April 18 Just to confirm, you are changing the base ISO. Jump between 4000 and 800 for a test. Link to comment Share on other sites More sharing options...
Nicolas POISSON Posted April 18 Share Posted April 18 If you are monitoring the log signal, this is the expected behaviour in Cine EI mode. Apply any LUT and you will see the changes. Link to comment Share on other sites More sharing options...
Sinan Gökhan Posted April 19 Author Share Posted April 19 when i am changing 800 to 4000... yes exposure change. but when i decrease for example 800 to 400 nothing change. and yes i applied a lut but it is still same 😞 Link to comment Share on other sites More sharing options...
Albion Hockney Posted April 19 Share Posted April 19 Are using the M-LUT in camera. for the FX9 you need to turn M-LUT on to see the changes as far as I know. if that doesn't work then there might be another setting causing the issue or less likely an issue with the camera. Sony menus are difficult. just keep messing with it. are you using an external monitor or do you have an SDI monitor you can try as well? Link to comment Share on other sites More sharing options...
