Jack Wormell Posted June 24, 2024 Share Posted June 24, 2024 HI Simple question (I think): I have a Bolex REX 4. I have a Sekonic L-398A light metre. I use the Cine numbers on the light metre for the reading. But I'm still unsure as to what exposure compensation I should be making from the light reading to the aperture on the camera. Half a stop open? A stop? Thanks for any guidance Jack Link to comment Share on other sites More sharing options...
Don H Marks Posted June 27, 2024 Share Posted June 27, 2024 (edited) Page 13 of the manual always works for me. "Real" speeds are how fast the shutter stops action "Adapted" speeds are the ones you would use with your meter. Just use the "Adapted" speeds from the table; there is no other 'compensation' needed. Edited June 27, 2024 by Don H Marks Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted June 28, 2024 Premium Member Share Posted June 28, 2024 Here's a copy of the original manual for a Rex 4: https://www.vintagecameras.fr/images/MonSite/BOLEX/H16_Reflex/_Doc/Bolex_H16Reflex_Manual_en_Revu.pdf There are a few ways you can meter. Either use the "adapted" exposure times listed in the manual - ie 1/80 sec for 24fps. This takes into account both the 133 degree shutter angle and the 1/3 stop light loss to the viewfinder. Or if using cine mode on a light meter (which assumes a 180 degree shutter) then you need to compensate an extra 2/3 of a stop (1/3 for the prism light loss and 1/3 for the difference between 180 and 133 degrees). The easiest method is to set your meter ISO at 2/3 stop slower, so for instance if using 100 ISO film you would set your meter to 64, or if using 250 ISO set your meter to 160 etc. Link to comment Share on other sites More sharing options...
Jack Wormell Posted July 1, 2024 Author Share Posted July 1, 2024 Thanks guys, I'll try these tips out. Link to comment Share on other sites More sharing options...
Patrick Cooper Posted July 19, 2024 Share Posted July 19, 2024 And if you're shooting negative film, I guess you'd want to open up that aperture even more. Maybe an extra half a stop at least. Link to comment Share on other sites More sharing options...
