Lukas Heinser Posted February 18, 2025 Posted February 18, 2025 Hi guys! I recently bought an Arri 16 BL EQ and am wondering about the mode switch you can see in the image, which is for making "quick changes between sound speed and non-sync speed" as the manual says. But it doesn't say which is which. The switch has three possible positions. It can be parallel to the body, one step to the right and even more to the right (in an almost 90 degrees angle to the body). Does anyone of you know which of these possibilities are for synch-speed? My goal is to be able to record audio digitally independently with an external recording device and to then line it up with the image. Thank you already!
Premium Member Duncan Brown Posted February 21, 2025 Premium Member Posted February 21, 2025 This says that switch is for "Sync/Pre-select/variable speed" Does that help? https://fm.hunter.cuny.edu/handbook/production2/prod/prod_manual-arri_bl.pdf Duncan 1
Premium Member Aapo Lettinen Posted February 21, 2025 Premium Member Posted February 21, 2025 if unsure it is best just to verify with tachometer or stroboscope light if the camera is really running in sync. then you will find the correct switch position and can ensure sync accuracy at the same time 1
Lukas Heinser Posted February 21, 2025 Author Posted February 21, 2025 7 hours ago, Duncan Brown said: This says that switch is for "Sync/Pre-select/variable speed" Does that help? https://fm.hunter.cuny.edu/handbook/production2/prod/prod_manual-arri_bl.pdf Duncan Wow thank you! That is probably meant from right to left, that would explain it. Thank you very much 🙂
Lukas Heinser Posted February 21, 2025 Author Posted February 21, 2025 1 hour ago, Aapo Lettinen said: if unsure it is best just to verify with tachometer or stroboscope light if the camera is really running in sync. then you will find the correct switch position and can ensure sync accuracy at the same time Good idea, thanks a lot!!
