Mike Panczenko Posted June 28, 2004 Share Posted June 28, 2004 A few days ago I asked how film ASA/ISO numbers are assigned. I don't think I was as clear as I could have been, sorry. I was wondering, and am assuming that equations are used on results obtained from certain tests (if I am wrong, please correct me), what equations are used and what tests are conducted to find the film speed. How is the number 500 arrived at, versus the number 50? I haven't been able to find this out anywhere. Thanks! Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 29, 2004 Premium Member Share Posted June 29, 2004 Exposure index: http://www.kodak.com/US/en/motion/support/faq/exposure.shtml Calculation of ISO film speed for still film color negatives: http://webstore.ansi.org/ansidocstore/prod...ISO+5800%3A1987 B&W still film speed: http://webstore.ansi.org/ansidocstore/prod...ku=ISO+6%3A1993 Color reversal still films: http://webstore.ansi.org/ansidocstore/prod...IT2%2E21%2D1994 Link to comment Share on other sites More sharing options...
Dirk DeJonghe Posted June 29, 2004 Share Posted June 29, 2004 May I suggest the reading of the classic " The negative" by Ansel Adams, available from most on-line bookshops. It explains how to set up B&W processing and how to use the zone system for exposure control. This is all for still photography but very applicable to motion picture. I recommended this book to a new-to-film DOP (he had a lot of video experience). He shot about 3 or 4 rolls of 5218 reloaded in 36 exposure cartridges and made phenomenal progress as a film DOP. Basically Adams recommends to do exposure tests and find where zone 1 (just above D-Min) falls. If you understand this then you will also understand that push processing a negative will not really increase the speed of the film, just add some density and give higher print numbers. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted June 29, 2004 Premium Member Share Posted June 29, 2004 The blackest black you will ever get is from the minimum density (D-min) of the negative. So unless you have enough exposure to have some shadow area image densities above the minimum density of the negative, you will not capture the information. With Kodak VISION Premier Color Print Film (2393), the blackest black you can get on the film is over 5.0 in density, or more than a 100,000:1 brightness ratio. Projection lens flare and ambient light in the theatre reduce this somewhat, but you still can achieve remarkably rich blacks on the screen. Link to comment Share on other sites More sharing options...
Mike Panczenko Posted July 4, 2004 Author Share Posted July 4, 2004 If you do have time, would you mind explaining so I don't have to buy the book? I'd understand if it's too involved,though. Thanks for the links. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted July 4, 2004 Premium Member Share Posted July 4, 2004 Does the actual ASA, ISO, EI number mean anything -- i.e. why is 100 ASA that number and not another? I understand why 200 is twice as fast as 100, etc. But how did that particular numbering system begin? Link to comment Share on other sites More sharing options...
Mike Panczenko Posted July 8, 2004 Author Share Posted July 8, 2004 I found out from a search, that the ASA number is defined as 10/H, where H is the exposure in lux seconds, at which certain image perameters are reached. The question still remains, though, what these image parameters are. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted July 8, 2004 Premium Member Share Posted July 8, 2004 A very good discussion of film speed parameters is in the Kodak technical paper "Technical Basis of Photographic Speed Determination, or What is a Normal Exposure" by Daan M. Zwick, SMPTE Journal, August 1979, Volume 88, page 533. Link to comment Share on other sites More sharing options...
Premium Member Laurent Andrieux Posted July 12, 2004 Premium Member Share Posted July 12, 2004 1) The asa settings don't fit to film neither video 2) you ahve different methods to determine one film sensitivity 3) The general formula is S=K/H where S is sensitivity, K a figure depending on the film, H the necessary lumination for obtaining a certain reference density this reference density depending upon the method : for instance, for b and w : K = 0.8, Rd (refence density) is 0.1 over the toe - Link to comment Share on other sites More sharing options...
