Gavin Peach Posted September 11, 2004 Share Posted September 11, 2004 Hi I am preparing a shoot where I want to create a colourful and dream like aura around my images. After reading an article on 'Eyes Wide Shut' in 'American Cinematographer' (Oct. 1999). I was interested in Larry Smith's description of how he push processed Kodak 500T 35mm stock to make the highlights blow out and help create a dream like image. I am interested in this above practice as I love the look of the picture and would be interested if anyone has any suggestions on using this technique on Super 16mm with 7218 and 7279 stock. I'm particulary interested in how much grain you would get using this process on this stock and in any colour bias's this may cause. +How much extra would push processing cost? and are there any alternative methods to achieving a similar effect? Thanks Gavin Link to comment Share on other sites More sharing options...
Guest fstop Posted September 11, 2004 Share Posted September 11, 2004 I think you must consider how Smith lit the scenes more than the actual pushing itself- on super16 you are gonna get really grainy on 500T, and your telecine is gonna have to be quite good on top of this. Didn't Smith use lots of compensatory fill and a ton of photographically bumped up practicals? From what I remember of the behind the scenes stuff, it wasn't particularly low light photography. I think you could get a dream like aura a lot more simply through overexposing through filtration and nets, or by pushing a SLOWER film, if you can afford it. You'll certainly get more colour. Link to comment Share on other sites More sharing options...
Gavin Peach Posted September 11, 2004 Author Share Posted September 11, 2004 Thanks for your help Yeah Smith did use compesatory fill and bumped up practicals (christmas lights) etc. The push process was used more to achieve a specific look than to facilitate low light levels. In order to make the lights appear much brighter and to flare out. He also used a Tiffen Low contrast filter on night time interiors. Im thinking of maybe using a pro mist to make the highlights flare out as another alternative. If anyone has any other suggestions they would be much appreciated Thank you Link to comment Share on other sites More sharing options...
Nitin Sagar Posted September 11, 2004 Share Posted September 11, 2004 i have shot 7218 xtensivly in the last one year....it is tailor made for digital post..on the other hand, even it is handeled optically it is not at all "grainy"...emulsion is made of grain.... it all depends on what format you are finally going to project? Link to comment Share on other sites More sharing options...
Jarin Blaschke Posted September 12, 2004 Share Posted September 12, 2004 I have a similar question regarding a shoot I mentioned in the "35 only" forum. It seems that out of necessity (night exterior anamorphic shoot) I might need to rate my film at about 640. I'm fanatic about having a rich negative, so I thought a push 1 with 5218 should be the best option. Am I in danger of losing much shadow detail this way, or does '18 still have the latitude to handle it? Would pushing '29 be much better at retaining those vast dark areas? How does the grain compare with those two options? It also seems that many prefer pushing the new stocks as opposed to just shooting '89. Thoughts? Thanks. Jarin Link to comment Share on other sites More sharing options...
Nitin Sagar Posted September 12, 2004 Share Posted September 12, 2004 bingo..just go ahead and shoot........'18 will stand by u Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted September 15, 2004 Premium Member Share Posted September 15, 2004 Generally, if you are trying to hold rich blacks while forced to underexpose, the "normal" contrast stocks like 5218 are a better choice than the lower contrast 5229. A "Push-1" ECN-2 process will increase contrast and granularity, and print to a "richer" black, but will not really get much more shadow detail. For EI640, using 5229 with a "Push-1" might be worth trying, as the push process will yield a contrast close to "normal" 5218. But expect a bit more grain. Link to comment Share on other sites More sharing options...
