Calibrating a light meter with the DVX
DavidSloan
> Do any of you guys work that way?
There is no good reason to, other than the fact that you will get paid more if you're seen waving a light meter around.
> If so is it a reliable method of lighting for video?
Absolutely not. Video requires far greater precision in exposure than is really possible using a meter.
I've posted on this a lot in the past, do a search.
Phil
Link to comment
Using a meter to LIGHT for video is fine; it's using it to set the final exposure on the lens that is questionable, where zebras, waveforms, just how it looks on a properly set-up monitor, etc. may be a more accurate way of exposing.
So if you are only using the meter to light a set and balance the lighting, it only has to approximately match the sensitivity of the camera -- probably getting within half a stop would be accurate enough to be practical. When I'm scouting a location for an F900 HDCAM shoot, I usually set my meter to 400 ASA as a starting point.
Link to comment
  • 3 weeks later...
