F Bulgarelli Posted December 14, 2004 Share Posted December 14, 2004 Hello forum, Is it possible to blow up super 8 negative to 35mm? Has anyone here done it? what does it look like? I'm thinking about shooting a section of a 35mm short on Super 8 and then do the blow up to 35mm as a part of the whole piece. We will be going to a release print. Thanks fo your help, Francisco Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted December 14, 2004 Premium Member Share Posted December 14, 2004 Probably the simplest thing would be to transfer the Super-8 to 24P HD-D5 and have that recorded out to 35mm. Not necessarily cheap though. I know that "American Family" on PBS, shot in HDCAM, has occasionally had Super-8 footage transferred to HD, at Laser Pacific maybe. Another method would be to transfer to 50i Digital Betacam (PAL) and use that for a transfer to 35mm. You would shoot at 24 fps, it would be transferred at 25 fps to 50i, it would get converted to 25P in post for the film-out, and the final film would be projected at 24 fps. I don't know of any direct S8 to 35mm optical printers -- if there are any S8 to 16mm optical printers, you could blow it up to 16mm and then again to 35mm. I had some Super-8 footage in "Twin Falls Idaho" but I just projected the footage onto a white wall and rephotographed it onto 35mm without any syncing. There is a pulsing to the image. Link to comment Share on other sites More sharing options...
F Bulgarelli Posted December 14, 2004 Author Share Posted December 14, 2004 Thanks David, Your technique sounds lie a good idea. Do you mind if I try it? francisco Link to comment Share on other sites More sharing options...
Dirk DeJonghe Posted December 14, 2004 Share Posted December 14, 2004 Studio Gamma in Liège Belgium has a Super 8 wet-gate for his Oxberry optical printer and he has made blow-ups from Super 8 negative to 35mm IP; not direct blow up to positive because he cannot color correct scene-by-scene. From this 35mm IP, a 35mm Dupeneg was made and this was color corrected as usual. Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted December 14, 2004 Premium Member Share Posted December 14, 2004 As mentioned in another thread, Kodak did an internal demo using a Super-8 gate on a Spirit DataCine to make a DI, and then wrote out a 35mm duplicate negative for printing. Looked surprisingly good, but "size does matter", and the graininess will betray the origin of the image. Certainly usable for a home movie "look" as part of a feature. Link to comment Share on other sites More sharing options...
Christian Appelt Posted December 15, 2004 Share Posted December 15, 2004 Andec Filmtechnik also does Super8 to 35mm optical printing IIRC, look here: http://www.andecfilm.de/html/start_english.htm Link to comment Share on other sites More sharing options...
