Premium Member Alessandro Machi Posted January 10, 2005 Premium Member Share Posted January 10, 2005 I use a Dichroic on a 1K spot from time to time. How much "brightness" in terms of f-stops am I losing when I use a dichroic? (I would do a test right now by simply taking the dichroic on and off the light but unfortunately the Dichroic recently broke.) Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted January 10, 2005 Premium Member Share Posted January 10, 2005 Hi, What sort of dichroic filter? There's a few (hundred.) If it's a tungsten to daylight correction, which is what I suspect you're talking about, you lose exactly the same amount as you would with any full blue or 80A filter; the only difference with a dichroic filter is that it doesn't gradually bleach out due to overheating. Phil Link to comment Share on other sites More sharing options...
Premium Member Laurent Andrieux Posted January 12, 2005 Premium Member Share Posted January 12, 2005 A dichroïc filter occures less loss than a gel. T to Daylight loss is only one stop loss when full CTB gel is 2 stops loss Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted January 12, 2005 Premium Member Share Posted January 12, 2005 Hi, How is that possible? I can believe that the substrate that the filter is made on would be less absorbtive than the gel, but that's not going to double the output. Phil Link to comment Share on other sites More sharing options...
Premium Member John Pytlak RIP Posted January 12, 2005 Premium Member Share Posted January 12, 2005 A dichroic filter will pass the desired wavelengths, and reflect the undesired wavelengths, and absorb relatively little light. So a well designed dichroic can more efficiently change the spectral qualitly of the light than a subtractive filter. Dichroic filters are commonly used in additive printers, and as IR filters in projection systems. Link to comment Share on other sites More sharing options...
