Premium Member Chris Keth Posted February 1, 2005 Premium Member Share Posted February 1, 2005 I've ruyn into a couple mentions of lighting fixtures that I don't know of. What are "dedolights"/"dedos" and what is a "source 4"? Link to comment Share on other sites More sharing options...
DavidSloan Posted February 1, 2005 Share Posted February 1, 2005 The official Dedo site has all the info you need regarding Dedo lights. Basically they make a variety of hard lights, which give you extremely cpntrollable beams. I'm a big fan of the DLH4...it's always on my equipment rental list; and the suction cup is genius. Source Four is a stage light that can be used as a spot light. It's also useful to toss in a pre made gobos, in the lens of the unit, for a quick pattern. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted February 1, 2005 Premium Member Share Posted February 1, 2005 The Source 4 is made by ETC and is essentially a modernized version of the standard stagelight called the Leko. It's an ellipsoidal light. http://www.etcconnect.com/products/products.asp?1 The Dedolight is also an ellipsoidal, just very small. Basically think of a light with a big glass lens in front, not like a fresnel or PAR lens, but more like a camera lens -- ellipsoidals are sort of like using a slide projector to create a spotlight. This allows them to project shadow patterns from gobo slides slipped inside the light (although with Dedos you need a projector lens attachment.) Link to comment Share on other sites More sharing options...
DavidSloan Posted February 1, 2005 Share Posted February 1, 2005 Dedos are amazingly easy to hide, so you can use them for cramped spaces. Also, they have a nice long throw so they're great for adding punch. This Sat I lit a scene by taking 6 4x4 kinos and essentially creating a wall out of them. I placed 3 side by side connecting the flaps with a no.3 spring clamp, and then another 3 right above those in the same formation. I then placed a bleached muslin over the entire thing and had the most amazing wrapping soft light I could ever ask for. Then I just strategically placed diffused dedos around the set for slight kicker punch, and some B-boards on the floor. This was shot on 7229 going to digibeta...will see dailies on Thu. :) Link to comment Share on other sites More sharing options...
Dan Salzmann Posted February 1, 2005 Share Posted February 1, 2005 Great little units. The lower wattage Dedo's can run on 30V and this can come in super handy. Link to comment Share on other sites More sharing options...
