Maurice Morales Posted January 17, 2020 Posted January 17, 2020 Hello, When would be a use to film in 4K DCI or 2K DCI (1.90:1)? I apologies if this seems like a obvious answer but I have found a obvious answer and thought It’d be best to ask experienced Camera Crew. Thank you for your time.
Premium Member David Mullen ASC Posted January 17, 2020 Premium Member Posted January 17, 2020 I guess a Digital IMAX screening might use a 4K 1.89 image.
Phil Connolly Posted January 17, 2020 Posted January 17, 2020 2.39:1 scope is the same width as DCI 2k of 4K. So if your framing for 2.39:1 you'd typically shoot in a 1.89:1 mode. The extra room at the top and bottom of the recorded frame is useful for reframing, hiding tracking markers, spotting the boom and giving you flexibility to make a pan and scan 16:9 It's rare to make a 1.89:1 deliverable, but it's a good ratio to shoot in when you crop to other aspect ratios. The point of 1.89:1 is that its in between 2.39:1 and 1.85:1. It cinema cameras for instance had a 2.39:1 shaped sensor, you'd need a massive crop to get to 16:9. Digital cinema projectors have the same shape 1.89:1 sensors - so crop at either the sides or the top and bottom for different aspect ratios 1
Premium Member David Mullen ASC Posted January 17, 2020 Premium Member Posted January 17, 2020 In DCPs, 2.39 uses max width and 1.85 uses max height. 1 1
Maurice Morales Posted January 17, 2020 Author Posted January 17, 2020 Thank you David and Phil. I was curious of the use case for this aspect ratio. I mostly work on 1:78:1 deliverables and mostly web content. I'm just a curious cat.
