Hi -
I just purchased an Arri S that's been sitting for some time. Motor runs, battery belt holds a charge, but this thing definitely needs oiled (not greased - oiled, as per the manual). Is 3-in-One oil OK to use, or should I be looking for something different.
Thanks!
Aaron
3-in-1 or sewing machine oil would be fine.
The user-accessible oiling points are only to lubricate the bearings for the sprockets and  counters. The movement is a seperate, much more precise assembly that is lubricated with specific greases, a job for a repair tech. If you’re interested to see what the oiling points lubricate, see the pics of the underside of the platine, roughly 12 or 13 pics down in my Arri S blog post:
http://cinetinker.blogspot.com/2019/02/arri-16st-service.html
  • Upvote 1
  • 4 years later...
