I recently got a Beaulieu s2008. I haven’t got the new battery in the mail, but when I look through the viewfinder everything is black. When I press the switch on the top of the camera I can see the very bottom portion of the frame. Is this an easy fix? If not, are there any recommendations for a repair shop that works on Beaulieus?
Probably just the shutter stopped in front of the viewfinder. Once you power the camera it should move into viewing position.
  • Like 1
Beaulieu 2008S cameras shall ONLY have 4,8 V.
To fit 7,2V or more in camera will only make problems. Be aware about this. To many have tried to use too high Voltage and get different problems.
Edited by Bjorn Andersson
  • Like 1
Bjorn, thank you for letting me know that. I have two original batteries that need to be recelled. I ordered a Lithium Ion battery kit off of ebay for the camera because I thought it would be easier. It was advertised to be used for the 2008, but the seller just got back to me and said it is 7.4V. Would you recommend to just recell the old batteries or change out the LI batteries in the kit I bought?
