Hi all,
I recently shot with my first rear projection screen, and not until we were shooting did I notice a feeling of “lag” or “drag” in what was being projected. Talent was directly up against the screen, with top down footage of ocean waves going by. I felt a very, very subtle stutter in the footage that was not perceivable by eye. Unfortunately this was an incredibly rushed setup so did not have time to ask for specs/adjustments. Could anyone advise as to what may cause this, and what solutions may exist?
Tricky to say without being able to see it. There's a number of places issues can arise with this sort of thing. Can you post footage?
was it a virtual rear projection setup (aka the camera being tracked with an unreal or similar background)?
Do you recall the projector settings? Was it a 144hz projector or less?
Was what you saw on the monitor or to the eye (or both)?
Was the camera on battery or was it running house power? Was it on the same circuit as the projector or a different one?
Do you recall the playback file's frame rate and the camera's frame rate?
Do you recall the device (and if a computer, the software) used to playback your projected material?
Questions I wish I had the answers to. Wasn't the most friendly projection team unfortunately. But, it was a rear projection setup that was pre-recorded footage from out in the world, what I saw in the monitor was not the same as what I saw in my eye. To the eye it looked perfectly smooth. Almost like the hertz refresh rate was causing the problem for camera. Camera was on battery power. Thats about all the answers I have.
I think without the answers to those questions we cant really know. I can tell you a while back a show I was on we just bought a $800 projector off amazon, I believe it was 60hz. playback was 30fps because of the approved background (which was licensed, annoyingly only came at 30fps) while we recorded 24fps. We were on battery, no phase sync. Looked great. Given the projector was 60hz I believe it was showing each frame twice on playback. We ran the playback off my macbook pro with the screen mirrored via HDMI.
We tried a 24fps conversion on the 30fps stuff the day before we shot, and that caused an image stutter, but the stutter was visible to the eye as well as on the monitor. That led us to go back to the original frame rate.
