Single perf 16mm film. Perf holes on the other side! Help
Guest Vadim Trofymenko
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
That diagram was in the link I posted.
It's b-wind. EIB means 'emulsion-in, b-wind'.
Camera film always has the emulsion in, it's a matter of which side the perfs are.
Well then, your magazine needs double-perf or a-wind film. The sprocket is on the opposite side from normal. So if you use single-perf you'll have to rewind.
Out of interest, what camera is it?
Link to comment
One more question tho, can somebody please show me where it says a A-Wind?
How the heck would I know what is what?!
Link to comment
Thanks man. That all I needed to know.
Link to comment
It's a Kinor 16 CX 2M by the way.
I'll have to re-wind even if I use a-wind stock?
Edited by Vadim Trofymenko
Link to comment
That's a b-wind. (Kodak SP number 457, 16mm 1-edge T core, b-wind)
I'd forgotten that the A-Minima is emulsion out. A-wind doesn't have to be, but the stock Kodak is supplying is. 200' Aaton loads will be emulsion out. Darn.
Edited by Zac Fettig
Link to comment
No you won't need to re-wind. But most A-wind stocks are lab stocks.
Are you sure the supply reel is supposed to be in the back? On most cameras, it's in the front. I don't know about the Kinor, but you may have loaded it backwards.
Any info on where I can get this stock. I can find only b-winds.
Yes that's correct way.
Link to comment
That's how it should look.
Basically I have to rewind b-winds since a-winds are hard to fins. And I guess are expensive.
Link to comment
That's emulsion-out.
A-winds are indeed lab stock. You could use double-perf but it would probably limit you to fresh stock.
Link to comment
Kodak do list some A-winds- I see a couple of 200' on cores in the current list. You could use double-perf but it would probably limit you to fresh stock. It would say '16N 7605(2994) 2R EIB' on the first can. Likewise EIA for A-wind. The other number are the perforation pitch in mm. (7.605) and inches (,2994). N is the perf type.
Link to comment
The emulsion should be towards the lens. But your rewound roll is fine for test purposes.
Hmm, oaky. The point is that I have a short film project coming soon and I want to film it using this camera. Do you think I will be able to buy a normal b-wind film, rewind it, shoot the film, rewind it back and send to the lab? Or I should buy a-wind reel?
Link to comment
Well I have just looked at my K3 and photographs of the Kinor and I'm now convinced that the Kinor does in fact take b-wind. I think you used double perf for your video.
The only alternative left is that the film you used had already been rewound. To be on the safe side you could use double-perf.
Link to comment
Just tell me what guys, when you open the film can and take out roll, emulsion side faces inside and base outside right?
Link to comment
I'd say rewind b-wind and shoot a test reel. Like 100' of tri-x reversal. Look and see how much scratching it causes. If it looks fine, then shoot with it.
I guess rewinding is not an option. Due to tension it makes lot of noise.
Link to comment
Forum Sponsors
CINELEASE
Film Gears
BOKEH RENTALS
Cinematography Books and Gear
