Dominik Bauch
Quasar led tube mounting
If you're going to velcro the clips to something, I'd just velcro the tubes. But I wouldn't rig them anywhere they were likely to fall onto anyone or anything. You could probably use big cable rip ties with a reasonable degree of security.
Share this post
Link to post
I wouldn't use sticky velcro directly on the back of a Quasar tube - the rear half of the tube is a heatsink, and it would get hot enough to make the adhesive melt and unstick.
Off the top of my head, I think #10 screws fit the holes in the Q-blocks.
What are you trying to attach your tubes to?
Share this post
Link to post
I'd say longer is better if the wood is deep enough.  Washers aren't strictly necessary but I'd probably use them if I was screwing the blocks down with power tools.
Share this post
Link to post
Screws can work, but i believe the blocks were designed for bolts and of using thin wood the bolts will be more secure.
The bolts go in through the front, then you use a washer and nut on the back. The hex opening in the front prevents it from turning, just use the right size bolt.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Visual Products
    The Original Slider
    G-Force Grips
    Just Cinema Gear
    FJS International
    Cinematography Books and Gear
