Jon O'Brien Posted September 7, 2023 Share Posted September 7, 2023 This might sound like a very basic question but what's a good formula for calculating FOV? I'm filming an orchestra concert soon and have just been told I can set up the camera in the sound room at the back of the theatre, or alternatively set the camera up amongst the audience, in the auditorium if necessary. I'd prefer to shoot the wide angle shot of the entire orchestra from the sound room if possible as the height is good and it's centred on the stage. The sensor size of the camera is Super 35. I'm wondering what the field of view will be of the stage, in other words how wide in metres from one side to the other will be the field of coverage of the stage, given the lenses I've got. I can hire various focal length range lenses. I could go to the venue and check but it would be good to know in advance. The distance of the camera to the stage will be 50m. If anyone has any advice I'd be glad to read it. Thanks. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted September 7, 2023 Premium Member Share Posted September 7, 2023 You’ll need to know the width of the stage, then calculate what angle of view you need to cover that width from 50m. Basic trigonometry. Then use any of the online angle of view calculators to determine what focal length has the required angle of view on a S35 sensor. 1 Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted September 7, 2023 Premium Member Share Posted September 7, 2023 There are free FOV calculators online. You can also use your smart phone on the location and a director's viewfinder app like Artemis or Cadrage, there are quite a few (not free though.) APS-C is the same sensor size as Super35 so you could also take an APS-C still camera with a zoom to the location and determine the likely focal-length. (Of course, you could use any camera format and then calculate the crop factor to find the equivalent focal length...) 1 Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted September 7, 2023 Premium Member Share Posted September 7, 2023 The thing is, this does get quite sensitive to exact sensor sizes, especially if you're talking about short focal lengths. Not everything that has a "Super-35" sensor has something that's exactly as wide as the Academy gate. The Blackmagic Ursa Mini series is pretty big, for instance. It doesn't often have a sufficiently significant impact to really affect things like lens coverage, but the field of view will be more affected. If it's bigger, no big deal, you can always crop in if you've a spit of resolution spare, but if you find an unusually ungenerous sensor size, I could see it being at least noticeable. 1 Link to comment Share on other sites More sharing options...
Jon O'Brien Posted September 8, 2023 Author Share Posted September 8, 2023 Yes good point Dom about the trig, I will ask for the stage width from the venue. It's funny I wasn't good at maths at school but later on really got into it, but then later after that I forgot a lot of it. Haha. Too much into the art side I am I think sometimes. Thank you David and Phil, your posts are very helpful and very much appreciated. Link to comment Share on other sites More sharing options...
Jon O'Brien Posted September 15, 2023 Author Share Posted September 15, 2023 Stage width is 10 metres. Link to comment Share on other sites More sharing options...
Jon O'Brien Posted September 15, 2023 Author Share Posted September 15, 2023 Using this FOV calculator: https://www.omnicalculator.com/other/camera-field-of-view I got a result of 12.5m if using a maximum focal length of 105mm which is what I've got at the moment for the C300 with sensor size of 26.2 x 13.8mm. For a 10m wide stage, that will do. If necessary I can crop the image, as it's being shot on 4K. Link to comment Share on other sites More sharing options...
