Premium Member joshua fry Posted January 16, 2024 Premium Member Posted January 16, 2024 Hi, Fired up my 16s does not seem to be working I can hear a very faint click. Would like to test the motor I understand I can run power to it directly. I understand the small round pin is positive where is the negative? do I just need to connect it up to the positive and negative to check it? many thanks
Mark Dunn Posted January 16, 2024 Posted January 16, 2024 The battery sleeve (between your fingers, the bit with the protruding pin) is the negative.
Premium Member joshua fry Posted January 16, 2024 Author Premium Member Posted January 16, 2024 great thanks. managed to get the motor working but its only seems to work on low setting like one and then I crank it up its good until stopped then have to return to 1. also the `FPS clock doesn't seem to work. many thanks
Fabian Schreyer Posted January 16, 2024 Posted January 16, 2024 You are probably running the motor backwards. When you do so, the tachometer will stay at 0 fps.
Premium Member joshua fry Posted January 16, 2024 Author Premium Member Posted January 16, 2024 (edited) thanks I will check this out Edited January 16, 2024 by joshua fry
Premium Member Duncan Brown Posted June 21 Premium Member Posted June 21 (Zombie thread, but I just noticed it) The variable resistor built into the rotating cap of that motor can get very flaky after all these years. If you take it apart, clean up the windings and the contact point, ever so slightly shift the contact so it's running on a slightly different path, and manage to get it all back together again without breaking anything, it will probably work a lot better. I'd smear a thin film of contact grease on there too. Duncan
