Geffen Avraham Posted June 8, 2024 Posted June 8, 2024 I recently tested a Konvas crystal motor I acquired with a 1M. I do not have a connector for it, so I ran it off a 12V 4.5A power supply, using two pins in the connector. It runs well, and measured with a tachometer does not drift. However, when the motor is stopped, it stutters. It stops, restarts, stops, and starts again - about 2 to 4 times. Rarely, if I release the button softly, it might stop at once. What can be causing this? Does it need more max current capacity that requires a battery?
Premium Member Dom Jaeger Posted June 9, 2024 Premium Member Posted June 9, 2024 Sounds like a parking issue, not battery related. I’m not sure how a Konvas parks, but if it uses a motor encoder, I’d start there.
Geffen Avraham Posted June 9, 2024 Author Posted June 9, 2024 (edited) It seems like in Olex’s videos, the motor also has the same stutter while stopping. It may just be normal behavior for these old Soviet motors? Edited June 9, 2024 by Geffen Avraham
James Compton Posted August 28, 2024 Posted August 28, 2024 Hi, Geffen. That on/off switch that you are using in the video is an aftermarket modification. It appears to be an electronic board issue. Contact forum member Aapo Lettinen. He repairs and upgrades Konvas motors.
Premium Member Aapo Lettinen Posted August 28, 2024 Premium Member Posted August 28, 2024 16 minutes ago, James Compton said: Hi, Geffen. That on/off switch that you are using in the video is an aftermarket modification. It appears to be an electronic board issue. Contact forum member Aapo Lettinen. He repairs and upgrades Konvas motors. I had similar style motor years ago, it too had the "stutter" when parking the shutter. To me it looked like normal behaviour... one can make shutter parking couple of ways and to me it looked like the Soviets made a rough working one with it alternating "full on-off" modes until sensor shows good enough result. one of the other ways to do it would be lower the power of the motor more when in parking mode. thus softer working but lower torque too which could cause issues if the camera has high friction. one of the other ways is to run the motor at slow non-crystal speed but closed loop speed control still on. for example CP16R does this, runs at fixed 3fps until the parking sensor gives signal to stop. Softer working and still very good torque. more complex to make 1
