orestis lambrou Posted July 14, 2004 Share Posted July 14, 2004 I was asked to use a 25-210 lens on an aaton xtr prod, but the support system of the lens is for arri. It wont fit on the light weight rods of the aaton. Has anyone used an sr bridge plate on an aaton, or has any idea it will fit? Tanks, Orestis Lambrou Link to comment Share on other sites More sharing options...
Mitch Gross Posted July 14, 2004 Share Posted July 14, 2004 I've used bridgeplate on Aatons plenty of times in the past. You can buy or rent plates that are specific to the camera or are generics that will fit any camera. The plates Arri (and others) make specific to the SR have a centering pin that may interfere with the Aaton base, but I think that the screw hole on the SR is further back on the camera body than on the Aaton so you may clear the pin with no problem. This is really a matter of checking with the rental house if you can't do a proper checkout in advance. Ask them to throw in a few spare bridgeplates of different designs just in case. Link to comment Share on other sites More sharing options...
orestis lambrou Posted July 17, 2004 Author Share Posted July 17, 2004 Thanks, I hope the sr plate will fit, because the lens and camera are coming from different rental houses, which sucks, sine the house the aaton comes from has no larger bridge plate, and the house the lens comes from, only has arri accessories! Anyway i hope that it'll work and thanks for your'e reply. orestis. Link to comment Share on other sites More sharing options...
Premium Member Olle Knutson Posted July 31, 2023 Premium Member Share Posted July 31, 2023 any uptdate on this? what bridgeplate is best for an aaton xtr prod??? Link to comment Share on other sites More sharing options...
Premium Member Tyler Purcell Posted July 31, 2023 Premium Member Share Posted July 31, 2023 7 hours ago, Olle Knutson said: any uptdate on this? what bridgeplate is best for an aaton xtr prod??? Any standard "film" vintage bridge plate will work https://www.ebay.com/itm/175818449635?hash=item28ef98a2e3:g:3dgAAOSwtytksm7y&amdata=enc%3AAQAIAAAA4Ba3nQjvxPMwVQhlTnmNbSwQhHs%2FFwnyd7nWDG0WWo30ZAYILCE9B%2BuavRYmR2zUoAtigEy7wYjIIJ4B4%2FNUU9%2FXA%2BrxMxCoIlwZquAHJJwBKiXCkj6Hhe8m4CBPVbW5T%2BpWGnY1WBjg8eYp839%2BbRYCkzGJTIOQP8CqO3mzEwOZbh0yd5v8w9zVApQuoFy%2FWwbksHGwnKp7QwMnsykgOlbeMut0tOQjNu1841acPqeJ1hUFEz3Wt883iPCiCCtkGl7JFfsvZyqs3YkhnHLvKA6IDUQe%2BrXeK2NkkIRYfxb6|tkp%3ABk9SR6zD6Na1Yg 1 Link to comment Share on other sites More sharing options...
Premium Member Olle Knutson Posted August 15, 2023 Premium Member Share Posted August 15, 2023 On 7/31/2023 at 9:30 PM, Tyler Purcell said: Any standard "film" vintage bridge plate will work https://www.ebay.com/itm/175818449635?hash=item28ef98a2e3:g:3dgAAOSwtytksm7y&amdata=enc%3AAQAIAAAA4Ba3nQjvxPMwVQhlTnmNbSwQhHs%2FFwnyd7nWDG0WWo30ZAYILCE9B%2BuavRYmR2zUoAtigEy7wYjIIJ4B4%2FNUU9%2FXA%2BrxMxCoIlwZquAHJJwBKiXCkj6Hhe8m4CBPVbW5T%2BpWGnY1WBjg8eYp839%2BbRYCkzGJTIOQP8CqO3mzEwOZbh0yd5v8w9zVApQuoFy%2FWwbksHGwnKp7QwMnsykgOlbeMut0tOQjNu1841acPqeJ1hUFEz3Wt883iPCiCCtkGl7JFfsvZyqs3YkhnHLvKA6IDUQe%2BrXeK2NkkIRYfxb6|tkp%3ABk9SR6zD6Na1Yg Thanks Tyler. Will it stay in place? Does it matter that there is only one hole to screw in to? Link to comment Share on other sites More sharing options...
Premium Member Tyler Purcell Posted August 15, 2023 Premium Member Share Posted August 15, 2023 4 hours ago, Olle Knutson said: Thanks Tyler. Will it stay in place? Does it matter that there is only one hole to screw in to? There is a pin that locks into the underbody of the camera which locks it in place on the XTR's and SR's. Link to comment Share on other sites More sharing options...
