zrszach Posted September 9, 2004 Share Posted September 9, 2004 They finally have a good picture of the arri d20 in the arri website. Does anyone know how much this camera costs, and if you can rent them? Thanks http://www.arri.com/entry/camera.htm Link to comment Share on other sites More sharing options...
Premium Member Keith Mottram Posted September 9, 2004 Premium Member Share Posted September 9, 2004 in film mode the pdf states that the native format is 4:3 as this camera also takes film lenses does this mean it would be possible to shoot scope with anamorphic lenses? Keith Link to comment Share on other sites More sharing options...
Premium Member John Sprung Posted September 10, 2004 Premium Member Share Posted September 10, 2004 does this mean it would be possible to shoot scope with anamorphic lenses? It should work fine. Any PL mount lens should do on the D-20 exactly what it would on an Arri film camera. -- J.S. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted September 10, 2004 Premium Member Share Posted September 10, 2004 But since the D20 signal is most likely to be recorded to HD, which is 16x9, what happens to the 4x3 image? Link to comment Share on other sites More sharing options...
Tenolian Bell Posted September 11, 2004 Share Posted September 11, 2004 Looks like from the brochure the full 4X3 image is in data mode which they say is 2260 resolution. Geez is that counting the bayer filter? Link to comment Share on other sites More sharing options...
Jason Rodriguez Posted September 11, 2004 Share Posted September 11, 2004 BTW, how are they planning on recording in "data" mode? I don't see a data connection on there anywhere, other than BNC's-in other words, no connection that I would call computer/IT friendly. Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted September 11, 2004 Premium Member Share Posted September 11, 2004 Hi, > But since the D20 signal is most likely to be recorded to HD, which is 16x9, what > happens to the 4x3 image? Well, think of it not as 16:9, think of it as a matrix of pixels into which you stuff whatever you like. PAL is 720x576 but that's either 4:3 or 16:9. Of course recording a 4:3 frame in 1920x1080 pixels is going to result in tall thin pixels but there's nothing inherently invalid about that. Of course if it crops to a wider 1.85:1 or 16:9 frame that's easy; scope is another issue. How they choose to map it, and whatever cropping the camera does, is another matter. Data is a much more sensible solution for this stuff. All this resizing and cropping about is a quality killer. Phil Link to comment Share on other sites More sharing options...
Landon D. Parks Posted September 12, 2004 Share Posted September 12, 2004 In video mode, you can output the signal in 1080p @ 16:9.... That is what is on the site anyway. Link to comment Share on other sites More sharing options...
Premium Member Keith Mottram Posted September 13, 2004 Premium Member Share Posted September 13, 2004 It seems to imply from the pdf that it can output in raw (to S2 or CineRam) and 1080p at the same time this raises the possibility of shooting with scope lenses and recording the monitored output to get a 2:35 image recorded at 16:9- this would be great. I'm hoping to get some information from IBC if I do I'll post it. Keith Link to comment Share on other sites More sharing options...
Premium Member John Sprung Posted September 14, 2004 Premium Member Share Posted September 14, 2004 But since the D20 signal is most likely to be recorded to HD, which is 16x9, what happens to the 4x3 image? Apparently they crop the top and bottom off to get a flat 16:9, just as we do with 4 perf film. I don't know if they've implemented this in the electronics, but it should be fairly easy to do an anamorphic squeeze to simply map the full 4:3 image into the HD tape format. We did that in telecine when we were doing the common sides / tilt and scan process. -- J.S. Link to comment Share on other sites More sharing options...
