Premium Member John Sprung Posted April 30, 2008 Premium Member Share Posted April 30, 2008 It's a CMOS and apparently same chip as the D-20 (D-21 now ?). If so, it would be interesting to see if they could put it in a camera and make a higher resolution native B&W camera. -- J.S. Link to comment Share on other sites More sharing options...
Site Sponsor Robert Houllahan Posted April 30, 2008 Site Sponsor Share Posted April 30, 2008 Hmmm -- So why did the installed base here in LA flip from 100% CRT to probably well over 90% line array CCD? -- J.S. Cintel dominated the market for decades and then the Spirit arrived... trends change and many shops have both a Spirit and a DSX or similar. I do not know about the figures exactly but I think Cintel is making a bit of a comeback. I personally feel the Spirit gives a bit of a hard look with color that is not entirely real. Many hi end shops are using telecine for dailies now and doing finish for TV spots on an Arriscan.. I do believe the CCD in the Arriscan is the same or similar to the D20 but without the bayer color mask, and it is on a motorized stage to allow it to scan up to 6K. Color in the scanner is constructed from a three to six pass individual R,G,B flash. I like the spirit but it is not the ultimate scanner and I feel it has been overtaken by other machines... that said I would not mind having one but they are very expensive , even on the used market. -Rob- Link to comment Share on other sites More sharing options...
Premium Member Stephen Williams Posted May 1, 2008 Premium Member Share Posted May 1, 2008 Hmmm -- So why did the installed base here in LA flip from 100% CRT to probably well over 90% line array CCD? -- J.S. Hi John, Maintenance costs probably. A CRT with a new tube can look wonderful, but without a great deal of TLC quality suffers. A CCD just works. Stephen Link to comment Share on other sites More sharing options...
Premium Member Keith Walters Posted May 1, 2008 Premium Member Share Posted May 1, 2008 The Spirit is a line array CCD machine, it has 4 lines, a B+W luminance, and three color lines... -Rob- I was under the impression the fourth CCD was infrared sensitive, for automatic scratch concealment. Since colour film is transparent to infrared, anything that shows up on IR has to be a scratch or manufacturing defect. The Arriscan has provision for an IR flash as well as red, green and blue for this reason. I would have thought a silicon photosensor would have completely the wrong spectral response to produce a precision luminance signal. Link to comment Share on other sites More sharing options...
Premium Member Keith Walters Posted May 1, 2008 Premium Member Share Posted May 1, 2008 It's a CMOS and apparently same chip as the D-20 (D-21 now ?). Reads to the sprockets per Mark from Arri on CML recently. But no Bayer striping in this case are you saying ? -Sam It is exactly the same chip. I have it on good authority that the chip was originally designed for the Arriscan, and that the D-20 was more or less a spinoff project, to give them something to compete with the Genesis if push came to shove. Link to comment Share on other sites More sharing options...
Site Sponsor Robert Houllahan Posted May 1, 2008 Site Sponsor Share Posted May 1, 2008 I was under the impression the fourth CCD was infrared sensitive, for automatic scratch concealment. Since colour film is transparent to infrared, anything that shows up on IR has to be a scratch or manufacturing defect. The Arriscan has provision for an IR flash as well as red, green and blue for this reason. I would have thought a silicon photosensor would have completely the wrong spectral response to produce a precision luminance signal. I have operated a Spirit-1 with a Pogle I do not believe that machine had a IR pass, the newer 2K/4K Spirits might. -Rob- Link to comment Share on other sites More sharing options...
