Sean Dahlberg Posted August 27, 2019 Share Posted August 27, 2019 (edited) Does anyone know if these are available to rent anywhere in the NYC area? I've searched a good deal but haven't come up with anything. Thank you! Edit: Will the 1.3x anamorphics made for 35mm do the trick, it should right? If so, I know I can rent them in NYC. Edited August 27, 2019 by Sean Dahlberg Link to comment Share on other sites More sharing options...
Premium Member Tyler Purcell Posted August 27, 2019 Premium Member Share Posted August 27, 2019 Vantage New York? Link to comment Share on other sites More sharing options...
Evan Walsh Posted August 27, 2019 Share Posted August 27, 2019 There's only a vantage LA as far as I'm aware. With the 35mm format 1.3x you'll be limited in the wide focal lengths as the 1.3x s16 set goes to 14mm where the 35mm only goes to 28mm Typically 35mm lenses are safe to use on 16mm camera's, as always test first if possible to avoid a mirror strike incident Link to comment Share on other sites More sharing options...
