Joshua Echevarria Posted July 15, 2020 Posted July 15, 2020 Hey been reading a bit but cant seem to get an answer for this question. I'm trying to figure out one thing when shooting with 500T film on the 1014XLS. I understand that the camera will read this as 400ISO which is fine but if I am using an 85B on the lens what do I set the internal filter switch to? Do I leave it on tungsten? Can't seem to get an answer for this. Any insight would be great
Mark Dunn Posted July 16, 2020 Posted July 16, 2020 (edited) 21 hours ago, Joshua Echevarria said: Hey been reading a bit but cant seem to get an answer for this question. I'm trying to figure out one thing when shooting with 500T film on the 1014XLS. I understand that the camera will read this as 400ISO which is fine but if I am using an 85B on the lens what do I set the internal filter switch to? Do I leave it on tungsten? Can't seem to get an answer for this. Any insight would be great Yes. Leave it on tungsten so the internal filter is out of the light path. The separate 85 will do the conversion. Edited July 16, 2020 by Mark Dunn
Joshua Echevarria Posted July 16, 2020 Author Posted July 16, 2020 22 minutes ago, Mark Dunn said: Yes. Leave it on tungsten so the internal filter is out of the light path. The separate 85 will do the conversion. Do you know if the exterior CCA Filter Switch overrides the internal switch?
Mark Dunn Posted July 17, 2020 Posted July 17, 2020 I don't know the camera model, but either switch will remove the filter. If the 500T cartridge is notched below the gate as it should be, you will need to use the external switch anyway. If not you won't need to.
Karim D. Ghantous Posted July 20, 2020 Posted July 20, 2020 On 7/16/2020 at 11:18 PM, Mark Dunn said: Leave it on tungsten so the internal filter is out of the light path. The separate 85 will do the conversion. Just a reminder to anyone who may not know: Super 8 cameras assume that you're using tungsten film, which is why the T setting removes the filter. The D setting adds one to correct the tungsten film for outdoor use. It's this way, and not the opposite, because it's better to slow down tungsten film when taking it outdoors than to slow down daylight film when taking it inside.
