Laowa 4mm to C-mount for Super 8mm?
Michael Koshkin
 Share
Hi All,
I have a Beaulieu 4008 with the Max 8 mod by Pro8 and the Angenieux 8-64. I’d like something wider. Thinking I should probably get the Schneider 6-66 at some point, but I’ve also been looking at C mount super wides like the Century 3.5mm. I know this topic has been discussed plenty on here.
I’m wondering what people think about adapting the Laowa 4mm fisheye to C mount? It was designed for small format mirrorless cameras so the lens mount options are not the most ideal (M4/3, EF-M, Fuji X, Sony E and L mount). With a quick search, the only C mount adapter I could find for any of those is a Fotodiox Fuji X to C.
Any thoughts on this? Think the flange will be off?
Also, since this covers M4/3 sensors, I’d assume that on Super 8mm with a Max8 gate, I’m gonna get the expected fisheye vignette in the corners, but would the lens cover the width of the gate? I would expect it would.
If a 4mm is gonna be something like a 16mm fov equivalent in Super 35 terms, I like the sound of the focal length.
Also, it’s a quite a bit cheaper solution than buying the Century 3.5...
Ive also looked at some c mount security camera lenses. Anyone used any they liked?
Link to comment
Since there is only .174mm difference between the flange focal distance of the large Fuji X mount and the small diameter of C mount, you will not be able to achieve infinity focus unless the adapter has a negative glass element built in to it.
Phil Forrest
Edited by Philip Forrest
measurement correction
Link to comment
24 minutes ago, Philip Forrest said:
Yeah, I was looking at the flange distance of different mounts on there before. Seems like M4/3 and L are the only mount versions of this lens that are more than 1mm greater. Maybe it’s a lost cause. I haven’t seen a mount for either of those to C.
Link to comment
If you're not averse to tinkering, go to the hardware store and buy a couple different fisheye door peep viewers. You'll need a simple convex/convex element behind the main lens to project the image properly on a film plane but between finding junker fixed focus Wollensaks and a few different size/focal length peep-holes, you'll still be under $50. They aren't as fast as a "real" lens for photography, but fun to play with. I have one of these stuffed into the filter holder of a fixed focus Wollensak 20mm and it resolves an image a little bigger than standard 16mm 4:3. This reminds me, I should get that lens out and play with it more.
Phil Forrest
Link to comment
Optivaron 1,8/6-66 with Schneider Aspheric ultrawide lens III wil give you around 4mm.
I use this combo with both my Leicina Special and Bolex DS-8,
it's  sharp, shows nearly no distortion, but tends to flare under critical lighting condition.
Good luck,
Volker
Link to comment
Good luck,
Volker
I wonder how bad this will vignette on a max 8 gate? Pro8 sells their modified cameras with the Angeneiux 8-64 and notes the Schneider 6-66 and 6-70 vignette. Wondering if that’s just a little in the corners or to the point of seeing a black circle around the frame...
Is this from the focal length or the physical lens circle/coverage size? And would the wide adapter make it worse? I don’t mind a little darkness in the corners for some stuff, but wouldn’t want to go with this combination if I’m gonna physically see a black circle.
Maybe I should be looking at wide 16mm lenses that will cover the larger frame?
Link to comment
On 3/3/2021 at 5:43 AM, Volker Bendt said:
Out of curiosity I made some test shots with my Leicina Optivaron and Leica M.
The image circle is around 7,5mm, with and without ultrawide lens.
It seems to be worth a trial.
Volker
Thanks for the research! I just shot a test roll of some very expired PlusX (Schneider 6-70mm and Schneider Ultrawide III adapter on a Beaulieu 4008 with max8 gate). Once cropped to 16:9 it does vignette but I can work with it. Blowing up the frame to about 103-104% gets rid of the vignette and at that point, it's still much wider than anything else I've found.
https://imgur.com/a/PzvplA1
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
Forum Sponsors
VidGear.com - Broadcast Video Warehouse
FJS International
Film Gears
Cinematography Books and Gear
