Premium Member Michael Leake Posted January 24, 2022 Premium Member Posted January 24, 2022 does anyone know how Dupixent commercials are produced. they seem to have a lot of cuts as opposed to one continuous shot. Mike Leake
Albion Hockney Posted January 29, 2022 Posted January 29, 2022 can you share a link to the spot your talking about? any specific questions ....that seems very broad
Premium Member Uli Meyer Posted January 29, 2022 Premium Member Posted January 29, 2022 Most commercials have a lot of cuts. Not sure what you mean.
Premium Member Michael Leake Posted January 29, 2022 Author Premium Member Posted January 29, 2022 https://www.ispot.tv/ad/O6SO/dupixent-asthma-better-breathing the above link is the Dupixent commercial. I have a lot of free time, being retired. The commercial appears to be one continuous shot. I may be imagining the following: At nine seconds, there is a lens flare, I think this is the first cut or splice (transition?), at 13 seconds a woman passes in front of the main character (second cut?). At 19 seconds a tree seems to be a transition, at 23 seconds another tree (transition) and at 35 seconds a person passing in front of the main actor. I am wondering if this Commercial is really one continuous scene, or for some reason, it is several transitions. Michael Leake
Albion Hockney Posted January 29, 2022 Posted January 29, 2022 It looks like they are doing some composition and fx work to hide transitions where you noticed. They did a good job though. To get all of that done in one take with that the dynamic camera movements, blocked action, not to mention working out the lighting because its essentially a 360 shot would be tremendously difficult.
Premium Member Michael Leake Posted January 29, 2022 Author Premium Member Posted January 29, 2022 thanks Albion. They have a couple of commercials like this. ML
Matthew Parnell Posted January 29, 2022 Posted January 29, 2022 (edited) I worked on this one as a lamp op. It was broken down into bite size pieces and shot over a couple days, if you look really closely you can notice the change of sun angles between the elements. They stitched it back together mainly using physical wipes in frame- extra crosses, lamp posts, trees etc as cutting points. Edited January 29, 2022 by Matthew Parnell 1
Premium Member Michael Leake Posted January 30, 2022 Author Premium Member Posted January 30, 2022 Matthew, thanks ML
