Premium Member Baltasar Thomas Posted May 19, 2022 Premium Member Posted May 19, 2022 (edited) Hi, For personal no-budget projects where I'm sadly not always able to use the ol' Aaton I'm looking for an affordable solution to shoot a digital S16 look and I've come to the conclusion that the BMMCC would be a good choice. Anyone selling? Preferably a package, preferably in Europe. This would be an ideal package, though I could source some things elsewhere of course. - Camera - Cage - A baseplate (doesn't need to be pro like Arri dovetail or VCT but should allow 15mm rods at the correct height) - A few batteries - A battery to d-tap solution - Something to make controls a bit more user friendly like the One Little Remote or a different remote solution - An OLPF like Rawlite - MFT to PL mount adapter Hit me up if you've got something :). Baltasar Edited May 19, 2022 by Baltasar Thomas
Premium Member David Sekanina Posted May 19, 2022 Premium Member Posted May 19, 2022 I do the same - i added a wooden camera PL mount to mine so I can use my 16mm lenses. Just as a heads up, most newer SD cards don't work with that camera anymore at all speeds (there's a whole thread on BMC forum). I bought ones from Angelbird that work flawlessly.
Premium Member Baltasar Thomas Posted May 19, 2022 Author Premium Member Posted May 19, 2022 5 minutes ago, David Sekanina said: I do the same - i added a wooden camera PL mount to mine so I can use my 16mm lenses. Just as a heads up, most newer SD cards don't work with that camera anymore at all speeds (there's a whole thread on BMC forum). I bought ones from Angelbird that work flawlessly. Thanks for the tip David, I'm actually planning to use PL glass as well so I've added the adapter to the list :).
Eric Arnold Posted May 20, 2022 Posted May 20, 2022 Cinegearpro in the UK makes a pretty good remote, I recently got one for mine. You could also look at the pocket 4K in S16 crop. Used prices for both are getting similar and better features on the 4K. I recently got my used BMMCC with a cage and Wooden Camera PL adapter for $400 Canadian, but I feel like I just lucked out.
Premium Member Baltasar Thomas Posted May 20, 2022 Author Premium Member Posted May 20, 2022 1 hour ago, Eric Arnold said: Cinegearpro in the UK makes a pretty good remote, I recently got one for mine. You could also look at the pocket 4K in S16 crop. Used prices for both are getting similar and better features on the 4K. I recently got my used BMMCC with a cage and Wooden Camera PL adapter for $400 Canadian, but I feel like I just lucked out. Thanks for the tip Eric. And that sounds like a steal you got there! Pocket 4K could do the trick as well, but I'd prefer shooting CDNG over braw. Have you compared the two? P4K crop mode vs BMMCC?
David Peterson Posted May 23, 2022 Posted May 23, 2022 (edited) On 5/20/2022 at 1:51 AM, David Sekanina said: Just as a heads up, most newer SD cards don't work with that camera anymore at all speeds ( Does ProResHQ 1080 30p still work? I don't mind if raw is a deal breaker, as it seems that in the past was the biggest issue with SD cards, getting raw to work On 5/21/2022 at 2:48 AM, Eric Arnold said: Used prices for both are getting similar and better features on the 4K. I do agree the interface and everything is better on the newer Pocket 4K than on the OG Pocket Edited May 23, 2022 by David Peterson
Premium Member David Sekanina Posted May 23, 2022 Premium Member Posted May 23, 2022 2 hours ago, David Peterson said: Does ProResHQ 1080 30p still work? I don't mind if raw is a deal breaker, as it seems that in the past was the biggest issue with SD cards, getting raw to work here is the thread: https://forum.blackmagicdesign.com/viewtopic.php?f=2&t=83050 many of the new cards are not recognized and can't be formatted by the camera. Some found cards that work at certain speeds. This was not worth the hassle for me, so I went with Angelbird, where when you tell them you want cards for this camera, they send you ones that work at all speeds, raw and Prores. 1
Alex bender Posted May 24, 2022 Posted May 24, 2022 Hello Baltasar I'm currently selling my Zcam E2-F6 package, which is definitely worth you considering. PL mounted with a range of recording options including, Prores 422HQ & ProRes Raw via the Atomos Ninja V. email me at - alexbenderdop@gmail.com and I can send you photos and further info. Best wishes Alex
