Boris Kalaidjiev Posted July 10, 2023 Posted July 10, 2023 Hello everyone, Is there a trick on how to keep someone's face underexposed by 2-4 stops but also give them a nice eye light so there is still life in the eyes? It is really hard to just pick up the light in the eyes without contaminating the whole background. I am mainly talking about interiors and not close ups. I've tried to light a 4x8 poly and keep it 10ft away from my subject very dim so that the eye could maybe pick-up the big poly without it being strong enough to actually light up my background. But the eye couldn't pick it up. Any tricks or ideas? P.S I also tried giving the actors eye drops so his eyes would be a bit more watery thinking that, that might be helpful but no effect so far. Thanks!!
Premium Member David Sekanina Posted July 10, 2023 Premium Member Posted July 10, 2023 (edited) I placed a 1.5m soft dome just 2-3 feet away from the model at a very low setting, so the reflection of the light in her eyes is as big as possible. Would i have placed it 10ft away, the reflection would be much smaller. You could also use a spotlight modifier or a Fresnel with barn doors to highlight just the eyes - but to me this always looks a little bit like Star Trek TOS or a Michael Bay movie ? Edited July 10, 2023 by David Sekanina
Boris Kalaidjiev Posted July 10, 2023 Author Posted July 10, 2023 The portrait looks nice! The spotlight idea you mean just to be eye level and to spot/cut it dead on the face? If that's what you meant then i run into the problem of having a weird shadow from the head on the wall behind. But it does help pull out the eyes a lot because then you see the actual light in the eyes. What would you suggest if you had a medium shot / medium wide shot? Thanks!
Premium Member David Sekanina Posted July 10, 2023 Premium Member Posted July 10, 2023 Oh yes, you wrote not a close up. A small bounce board out of frame reflecting light upwards into the eyes maybe?
Premium Member Stewart McLain Posted July 10, 2023 Premium Member Posted July 10, 2023 Pretty sure what you're looking for is an Obie light. https://tiffen.com/products/obie-light Of course, you don't have to use that specific brand. Just the basic idea - a small low wattage light on camera that's only purpose is to reflect in the eye and not to provide illumination to the subject. This is good article on eye lights with some other ideas beyond the one I just mentioned: https://theasc.com/blog/shot-craft/eye-lights 1
Guillaume Cottin Posted July 10, 2023 Posted July 10, 2023 I am not sure if there even is a perfect trick to do this. The lower the light levels, the harder it is to create an eye light that will not have an effect on the rest of the lighting. Assuming you like a round eye light, my go-to tool is obviously the Rosco Dash and Dot diffuser mounted on the camera or close to it. It’s fast to set up and looks great even on a medium. But for wider shots, i would use something like a 3ft lantern in which I would probably put a 60w COB (60c) dimmed way down, or even just a NYX bulb if you want to go even lower (adapting the bulb socket to a Bowens softbox). I would put it on the key side and at the most reflective angle possible and as far away as possible. In your case of under-exposure it’s just a matter of getting it very dim, as we are not illuminating the subject but using the reflection of the source in the eyes.
Premium Member David Mullen ASC Posted July 10, 2023 Premium Member Posted July 10, 2023 There is no single trick. For one thing, as the shot gets wider, the eyes are smaller in the frame so there is less of a reason to bother with an eye light. On "The Marvelous Mrs. Maisel" we didn't shoot close-ups, our singles tended to be waist up or elbows up in size. I often used a Litemat 1 under the lens to bring up the eyes but kept dim to not flatten contrast too much. The eyes are highly reflective so to some degree there might be a happy moment where the camera and light is far enough to not be adding too much film while still creating a bright reflection. Here is a shot I did where I couldn't use the Litemat 1 under the lens because the camera was on a slider pointed at the actor, so I used a "placemat" LED taped to the tripod head under the lens, basically a small white card with LiteRibbon taped to it, about 6"x6", maybe larger. I zoomed into the frame to make the eye light more obvious in this post: Enlarged: 6
Premium Member David Mullen ASC Posted July 10, 2023 Premium Member Posted July 10, 2023 Also keep in mind that the overall contrast affects the eye light. If you use a higher-contrast LUT with somewhat crushed shadows, like a skip-bleach / ENR print look, then the eye light being a highlight tends to pop more when the shadows go darker in comparison. Or you can think of it that you can use a brighter eye light even if it adds fill because the contrast of the LUT will cause some shadow detail to drop off. 2
Domen Martincic Posted July 3, 2025 Posted July 3, 2025 On 7/11/2023 at 12:05 AM, David Mullen ASC said: There is no single trick. For one thing, as the shot gets wider, the eyes are smaller in the frame so there is less of a reason to bother with an eye light. On "The Marvelous Mrs. Maisel" we didn't shoot close-ups, our singles tended to be waist up or elbows up in size. I often used a Litemat 1 under the lens to bring up the eyes but kept dim to not flatten contrast too much. The eyes are highly reflective so to some degree there might be a happy moment where the camera and light is far enough to not be adding too much film while still creating a bright reflection. Here is a shot I did where I couldn't use the Litemat 1 under the lens because the camera was on a slider pointed at the actor, so I used a "placemat" LED taped to the tripod head under the lens, basically a small white card with LiteRibbon taped to it, about 6"x6", maybe larger. I zoomed into the frame to make the eye light more obvious in this post: Thank you for a nice example! If I may ask, what is the reason you put the Litemat under the lens and not over the lens?
Premium Member David Mullen ASC Posted July 3, 2025 Premium Member Posted July 3, 2025 People tend to look down so the light under the lens shows up better, plus I'm also using it to reduce bags under the eyes. The only downside is that is also adds light under the chin. Also I've found that people with deep-set eyes catch a lower eyelight better because their brow shadows a light over the lens unless it is a longer-lensed close-up. On a wider-angle lens closer to the face, the top of the mattebox can be too high relative to the face and the center of the lens. Plus the focus-measuring horns of the Preston/Lightranger are often up there. 3
Domen Martincic Posted July 3, 2025 Posted July 3, 2025 4 hours ago, David Mullen ASC said: People tend to look down so the light under the lens shows up better, plus I'm also using it to reduce bags under the eyes. The only downside is that is also adds light under the chin. Also I've found that people with deep-set eyes catch a lower eyelight better because their brow shadows a light over the lens unless it is a longer-lensed close-up. On a wider-angle lens closer to the face, the top of the mattebox can be too high relative to the face and the center of the lens. Plus the focus-measuring horns of the Preston/Lightranger are often up there. Thank you very much for a quick answer!
Premium Member Zack Mahar Posted September 14, 2025 Premium Member Posted September 14, 2025 I think you’re on the right track with a larger source. In general, a source of light will be close to pure light regardless of how you’re exposing. I’ve been using a rosco dash or MC with a dot diffusion close to the talent at an extremely low intensity. This makes the source bright enough to catch but doesn’t illuminate the face too much. It just needs to be at the right angle and large enough relative to the subject so it appears in the reflection of the eye.
