Sign in to follow this
Max Moosbrugger
s16 zooms compatible with M4/3 cameras
I'm curious to see what the options are for ss16 zooms with a M4/3 camera(specifically the Bmpcc4k). I'm aware that when using c mount lenses you'll pretty much always see a vignette and need to crop in on the image, but I've seen people such Wolfcrow use super 16 pl primes on the GH5. He did say that when it comes to the ultra wide focal lengths you'll be out of luck. I'm wondering if there's a relatively affordable zoom that has minimal to no vignetting at least 18 milimeters.
Share this post
Link to post
are B4 zooms out of question? the ones with extender tend to cover slightly larger than S16 easily. I used to use one with the GH4 and it worked fine with it on UHD mode when using the 1.7x extender the lens had built in (about 15mm wide sensor on the camera or so) . I think the lens had a wide end of something like 4.7mm or so which makes it nice wide angle even with the extender and sensor crop
Share this post
Link to post
BMPCC4k has a 2.6K windowed sensor mode that should be around the same size of super 16mm film, so any zoom made for s16mm should cover the cropped sensor without vignetting.... IIRC that 2.6k crop mode was added in firmware update 6.6
If you're lucky to find one used, go for the Canon 8-64mm T2.4... Really lovely glass.
B.
Share this post
Link to post
fujinon 8.5x b4 zoom  5.5 - 47mm with 1.7x extender I think
Share this post
Link to post
I use a cooke super16 10.4-52mm Varokinetal, and a Canon super16 10.6-180mm on my GH5.
Covers 4k (crop mode 4k is almost exactly same size as super16 gate) perfectly, zero vignette. Absolutely stunning lenses.DSC-0796.jpg
Edited by James Coleman Rogers
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Gamma Ray Digital Inc
    FJS International
    Just Cinema Gear
    G-Force Grips
    The Original Slider
    Cinematography Books and Gear
