I've read all the other "I just got an NPR and I have so many questions" posts...and so I don't have so many questions.  But I have a few obscure detail queries, so I thought I'd post them with pictures just so it will be more fun...
Is this motor a non-crystal sync version with a 50Hz pilotone signal?  And does the pilotone come out of that 3 pin connector on the side?  Anyone have a wiring diagram?  (Yeah, I know, a screwdriver and/or an oscilloscope would give me the wiring diagram in short order, but I figured someone might just have some documentation handy.)
Duncan
Is this a late serial number?  Certainly doesn't seem like an early one, but I have no idea how many they made.  I'm sure nowhere near the nearly-20K Arri made of the 16S.
Duncan
Is this the original battery and charger?  Or something someone whipped up from Radio Shack parts?  I have yet to test it electrically.
Duncan
I did figure out, taking apart that battery pack, that the charger is definitely not original.  The battery pack was rebuilt in 2001 in Australia.I found the original 250V charger buried in the case.  Two small 6V sealed lead acid batteries wired in series that weigh a ton and only produce 3500mAH.  I'll whip up something better than that (but I can't test the camera until I do since the SLA batteries are dead.)
Duncan
That's a late serial number. The motor is an early one. Those motors were heavily modified, so it's very difficult to say if it is in the original condition. It makes sense that the XLR connector on the sides carries pilotone signal, but is that helpful today?
Several motors were converted to crystal sync back in the day and AZ spectrum can convert them today, but the guy is always busy. I don't see anything wrong with the base. It was a modular camera, there were several motors, viewfinders and bases available, so it may not be a Perfectone one, but looks like it is for Perfectone.
I've never seen an original battery per se. I mean there was not a case like the ones used on the Eclair ACL. People used battery belts and big batteries back in the day because cells were not as efficient as they are today. I use lead acid batteries to power my camera (4 & 7Ah) but you can use pretty much any 12v battery with 4Ah or more.
Oh it's probably the original base.  I was referring to the 14 or 15 extra holes drilled and threaded in it!
I have some mad-scientist plans for Pilotone so yeah, if that's an additional place to grab it that might be interesting to me.
Duncan
Well seeing as how I started with a bunch of pictures, might as well turn this into the NPR-porn thread.  I know I sure would have appreciated some more high quality pictures on the net when I was considering buying one, so I'd better understand what I was getting (and getting into!)
Duncan
More questions with pictures!  What's the weird screw within a screw above the viewfinder port?  What's the stud with a hole in it on the other side of the handle from that?  And what kinds of things mount to the bottom plate?  I've seen on some cameras a single round rod mount bracket, like for a matte box or something - anything else?
Duncan
Here's what my focusing screen looks like.  I'm guessing the wide-crop-in-post guidelines were added by someone later on?  The camera certainly isn't modified to shoot Super 16.
Duncan
  • 1 month later...
Hey Duncan. I had you pegged as prob'ly NSFRTFM.
The rounded corners frame looks like the TV safe area, the area assumed to be received on the goggle box. Visual products have a nice picture with definitions...
- projected area
- transmitted area
- "safe TV action" area on the receiving TV.
https://visualproducts.com/equipment-for-sale/s16-16mm-cameras/
scroll down...
It's a big crop to TV safe, especially when you think of the lower resolution film stock back in the day.
