Premium Member Duncan Brown Posted January 10, 2023 Author Premium Member Posted January 10, 2023 I never saw any lamps inside the ACL motor, but I didn't get into the actual motor housing...as it looked hideously complicated to get in there. Lots of wires with no slack. But maybe it's time to dive in! (Since I seem to have somehow wrecked the circuitry anyway ? ) I have a lot of respect for that design... I'm sure Aapo has a lot of respect for how they packed it all in that space with decades-ago technology! I would have less respect for the design if it depended on two unreachable incandescent bulbs. Do keep us posted on the status of your repair! I did have a Perfectone NPR motor once that had two light bulbs where one normally is, and couldn't figure out what the second one was for... but those were just outside indicator lamps, nothing to do with the motor itself? Duncan
Premium Member Steven Jackson Posted January 11, 2023 Premium Member Posted January 11, 2023 I will keep you posted on the repair and in the mean time, please post photos of the motor if you decide to delve into it. Very curious to see what is there.
Premium Member Steven Jackson Posted July 31, 2023 Premium Member Posted July 31, 2023 On 1/10/2023 at 6:30 PM, steven jackson said: I have the latest version heavy duty motor that will only go slow and too fast with the amber light staying lit all the while. I was in contact with an Eclair tech in France and he told me the motor speed control is aided by two very small incandescent lamps which act as a tachometer, that, like normal light bulbs, burn out, and my motor displays the symptoms of that being the issue. The bulbs are still available but are covered in epoxy somewhere within the motor...I don't know much more than that. I'm sending him my motor for repair and hopefully that will fix it up. I'm wondering if your motor had this issue and if, when dismantling the motor, you noticed these small lamps?? According to the tech, the verification is simple, the repair less so. Further to this post, the tech, Christophe Goulard, has passed away and he did not get around to repairing my motor, so it's very kindly being sent back to me and I'm hoping someone else may be interested in exploring this type of repair, which on the surface, sounds kind of basic.
Premium Member Steven Jackson Posted November 4, 2023 Premium Member Posted November 4, 2023 On 1/11/2023 at 12:50 AM, Duncan Brown said: I never saw any lamps inside the ACL motor, but I didn't get into the actual motor housing...as it looked hideously complicated to get in there. Lots of wires with no slack. But maybe it's time to dive in! (Since I seem to have somehow wrecked the circuitry anyway ? ) I have a lot of respect for that design... I'm sure Aapo has a lot of respect for how they packed it all in that space with decades-ago technology! I would have less respect for the design if it depended on two unreachable incandescent bulbs. Do keep us posted on the status of your repair! I did have a Perfectone NPR motor once that had two light bulbs where one normally is, and couldn't figure out what the second one was for... but those were just outside indicator lamps, nothing to do with the motor itself? Duncan To finally get back to this: I just had several ACL HD motors repaired at AZ Spectrum (since my original contact in France for the repairs passed away) and the motor that I discussed earlier that possibly had burned out motor speed control lamps did indeed have this issue. AZ Spectrum replaced both incandescent bulbs with led lamps. I had three motors repaired, and I must say, at a reasonable cost, and all three showing different symptoms. The one mentioned above with erratic speeds, one that had a sync light turning on, but otherwise no movement, and a third that showed no signs of life at all and would blow fuses. All three were repairable. Obviously, this makes me re-think the notion that once an acl motor goes out, it's finished and it would seem that the issues are electronic component related rather the motor being burned out.
Tyler Fukuda Posted August 12 Posted August 12 On 11/4/2023 at 1:17 AM, Steven Jackson said: To finally get back to this: I just had several ACL HD motors repaired at AZ Spectrum (since my original contact in France for the repairs passed away) and the motor that I discussed earlier that possibly had burned out motor speed control lamps did indeed have this issue. AZ Spectrum replaced both incandescent bulbs with led lamps. I had three motors repaired, and I must say, at a reasonable cost, and all three showing different symptoms. The one mentioned above with erratic speeds, one that had a sync light turning on, but otherwise no movement, and a third that showed no signs of life at all and would blow fuses. All three were repairable. Obviously, this makes me re-think the notion that once an acl motor goes out, it's finished and it would seem that the issues are electronic component related rather the motor being burned out. One of your motors has the same issue as what mine is going through now, but i'm not sure if it's related to these bulbs though. Once Andrew at AZ Spectrum is back from vacation, I plan to send mine in for repair. Symptom: Motor will want to initially fire, turn maybe 180º-360º, then stop. The sync light will stay on while the camera is on. Inching knob is completely free and can be turned by hand with not much resistance. Power has been checked for correct Voltage and Amperage. Using a donor motor currently and confirm the camera does run. If it's related to positioning due to a feedback loop provided by the bulbs, I imagine the camera has no input and just wont spin as it doesn't have a signal to base itself off of? But this is just a theory...
