Karim D. Ghantous Posted July 10, 2022 Posted July 10, 2022 The camera goes back to the 1920s, but someone has built a modernised version with these specs: Quote Super 35, 18x24mm, 4 perf movement, Olympus OM mount 180 deg shutter (constant) 8, 16, 18, 24, 25, 32 fps 12-24V power Wireless RUN Fischer 11-pin accessory out 12-24 V Fischer RS-3pin for RUN https://www.instagram.com/p/CfzK1EDK0y0/?igshid=YmMyMTA2M2Y= 1
Premium Member Uli Meyer Posted July 10, 2022 Premium Member Posted July 10, 2022 19 minutes ago, Karim D. Ghantous said: The camera goes back to the 1920s, but someone has built a modernised version with these specs: https://www.instagram.com/p/CfzK1EDK0y0/?igshid=YmMyMTA2M2Y= That someone is Daniil Nevskii. He is converting my Arriflex 2C to 2perf and PL mount at the moment. He's a bit of a camera wizard.
Premium Member Dom Jaeger Posted July 10, 2022 Premium Member Posted July 10, 2022 I love the Kinamo, wrote a post about it way back: Unfortunately many of the links are broken now, including all the photos I took of the mechanism inside while I overhauled it. Here’s a link to the wonderful little film Joris Ivens shot with one back in 1929, which I always think is a great example of what you can do with motion pictures with the most basic of tools: I love that Daniil has made a modern version, hope it gets past prototype. 1
Premium Member Simon Wyss Posted July 10, 2022 Premium Member Posted July 10, 2022 Mr. Nevskii is not right with the Sept by FACT-Debrie. That is a true cinematic camera. It even has a pair of register pins in the same position as a Mitchell has. The Sept has a conical two-blades shutter and a lens bayonet. It takes five meters of film, enough for a 15 seconds shot.
Karim D. Ghantous Posted July 11, 2022 Author Posted July 11, 2022 13 hours ago, Simon Wyss said: Mr. Nevskii is not right with the Sept by FACT-Debrie. That is a true cinematic camera. It even has a pair of register pins in the same position as a Mitchell has. The Sept has a conical two-blades shutter and a lens bayonet. It takes five meters of film, enough for a 15 seconds shot. 15 seconds is simply a stills camera with a really fast motor drive. That's not a cinema camera IMHO. Even Super 8 at 24fps gives you over two minutes! 1
